When I got my 2002 900 I left it in and paid my local Yamaha dealer less than two years and only 5000 miles ago to strip and clean both my front calipers, replace all the seals and renew the fluid, the pads were like new so I didn't change them.
The bike was used for most last year doing a short commute to work and back, used as a shopping trolley and it was my only transport for about a year but now its used for pleasure only, I'm a plodder and seldom use my brakes hard and usually wash and dry the bike if its been out in the rain etc before covering it up so I figured all I should be doing at present as the pads still have loads of meat on them, is just a good scrub up and bleed through of some fresh fluid.... the simplest of jobs always seem to turn into a whole kerfuffle for me and this ones no exception unfortunately.
After taking the pads out and giving the callipers a clean I then proceeded to bleed through new fluid but soon realised that it just wasn't happening, nothing at all was coming through the nipples when using a vacuum bleeder so I removed the screws completely and this is what they looked like, yes there is a hole there but it took ages to clear it with a needle and airline and where it screws into the caliper was full of rust.
I ordered new stainless bleed screws in size M8 x1.25 and this is what I got below, I didn't notice the flat bottom until after they arrived and I couldn't get these to make a seal at all.
I then ordered these ones, same size and had my fingers crossed that the pointy bottom in the photo on the website was what I was getting lol, here's what arrived.
So after lots of gentle scraping with a needle and cleaning with brake cleaner/fluid/cotton buds to remove the rust from the caliper bleed screw threads I find that the new bleed screws are also not making a proper seal. I figured it was leaking through the threads so used some Teflon tape around the bleed screw threads to test my theory and it does make a seal but I would not ride the bike without the bleed screws making a proper seal but I am unsure as to how I should now proceed, I would be very grateful for any ideas please as im stuck? Thanks.
No teflon tape
http://i33.photobuck...zpsd6aeea57.mp4
With tape
http://i33.photobuck...zps07752c48.mp4
Inside thread after cleaning
http://i33.photobuck...zps92a226f3.mp4
Edited by nakeddivy, 02 August 2014 - 12:55 am.
