Help
Posted 25 November 2007 - 04:53 pm
Just indicators and hazard switch not functioning, everything else on the l.h. side is fine, any thoughts please on most likely cause? Will it be bulb, fuse, connector or something other.
All I did when I got back was try some WD40 into the switch, which hasn't had any magical effect. If I'd done anything yesterday when I'd stripped it and moved the rad to change plugs surely they'd have not worked from the off?
Your wisdom and suggestions appreciated.
Posted 26 November 2007 - 01:35 pm
Posted 26 November 2007 - 02:05 pm
think i have a spare in my shed in deepest darkest Essex, should be back there on Friday, but working from home so canne deliver til the monday at the earliest
Posted 26 November 2007 - 03:08 pm
Is a total 'blackout' for my case!!!
Can't even crank up my ride, is the main fuse blown... tink it should be ard 30/40A type.
The cause of the blown up is the faulty rectifier.
Posted 26 November 2007 - 05:14 pm
I checked the bulbs and it seems the last one was gone, although I couldn't really tell (old-age eyesight) so I changed it and it still didn't initially work but I turned the bulb a bit further in the socket and that seemed to do the trick.
Not sure if the original bulb was OK too and maybe just wasn't correctly seated, but anyway I'll leave well alone as it's now OK.
