Posted 18 November 2014 - 10:56 pm
I once cooked a landrover overdrive shaft in the oven ready to install the inner bush from the freezer.
Took the chicken out that was in the way, did the shaft, popped the chicken back.
At dinner time, the chicken tasted very odd, it had absorbed the gear oil fumes left over from the shaft.
I was getting away with saying the chicken must be off, until the wee lad piped up " do you think us cooking the landover gear in there with the chicken might be causing it mum ? Never trust kids, they always spill the beans.
Had to take the whole family out for sunday dinner at some posh place of swmbo's choosing, so the job cost me a fortune.
