Pinlock Contrariness
Posted 06 February 2015 - 02:40 pm
......I tend to ride with my visor open a click to avoid misting-up......but it feels draughty.... in this weather especialy!
My dilemma is that I really like the graduated visors (darker at the top, obviously) available from Bob Heath, which I find v.helpfull in low-sun conditions....but maybe because B.H have their own anti-mist product, they don't do a Pinlock version of the grad-ed visor.
Has anyone attempted to convert a non-Pinlock into a Pinlock.....drilling? inserting 'pins'?......
.....or any ideas?
..........Jiff.
Posted 06 February 2015 - 03:14 pm
I was under the impression you could drill the visor yourself using a template from Pinlock/ I've never done this myself, however. The only time I ever had a Pinlock was one an Arai XD3/TourX. I was too chicken to drill the existing visor, so I bought a pinlock ready one. Strange that the most expensive helmet I ever owned fogged up the worst.
Actually, here's a quick google image:
Posted 06 February 2015 - 03:25 pm
Quite contrary....
Posted 06 February 2015 - 03:32 pm
I have a Shark pinlock and its lost its seal like a double glazed window does. Will be going back to the shop if I can ever remember to take it with me next time I'm in town.
I was a genuine Shark item so I should imagine drilling it yourself would be a bit hit or miss.
Posted 06 February 2015 - 03:44 pm
It was easy came with a template and the correct size drill. Just follow the instructions and it is a 10 minute job.
Most helmets now come with a pinlock fitted they do work well.
Edited by Gasman, 06 February 2015 - 03:45 pm.
Posted 06 February 2015 - 06:30 pm
I bought an AGV at the bike show some years ago and they drilled it for me there on a jig, so may be worth checking if any shops have a jog for it.
YamahaSam, as Dandy said the pins are eccentric, I had trouble with mine misting up at the bottom and realised it was seating against the visor properly, twiddled one of the pins a bit and it now seals fine.
Posted 07 February 2015 - 03:02 pm
I've drilled my own.
You get a template with the pinlock and pins too. Just make sure that you are 100% about location before drilling.
Also I used a brad point bit for the starter hole, then the require sized bit to finish off. The brad point bit helps avoid the bit running across the visor!
Posted 09 February 2015 - 12:46 pm
(as suggested, a kit is available which includes template, suitable size drill, buttons etc)...£23.99
It appears, that a grad-ed pukka visor for my Shoei Multitec, Pinlock-ready(drilled & buttoned) is available, which would cost £65, then plus the Pinlock insert would take it up to £85 !
.......non-grad-ed would be £20 cheaper.
Bob Heath would supply a grad-ed visor, with their own 'anti-fog coating' for £32....
......a BH grad-ed visor, without the coating would cost £ 29.00
............then plus the Pinlock DIY kit @ £23.99 = £52.99 total
.....so, if anyone's still awake, scanning through all of the above offers a variety of alternative routes to no-mist, low-angle sun nirvana...
.........Jiff
Posted 09 February 2015 - 01:01 pm
Didn't someone link a visor that slots in around the padding at the top of the visor opening.
I'll see if I can find it.
Posted 12 February 2015 - 08:50 am
Well I never. Works a treat although I managed to shear one of the pins. Should have popped it out then turned it & put it back in. Got 4 off ebay. What would we do without ebay
