The Tdm Is Going Nuts Again !
Posted 15 October 2012 - 11:20 am
describing it fully just in case anyone else has this happen on theres. Mine is 97 model.
took the starter solenoid off and decided it was faulty after checking continuity on wiring which ruled wires out. Cut the top off it to inspect and it was seriously green inside! So ordered one and will keep up to date on here . Anyone else had this problem? Did a new unit sort ? Might seal this new unit somehow to stop moisture getting in.
Posted 15 October 2012 - 11:32 am
Yeah, it's a fairly common problem although the symptoms can differ.
Posted 15 October 2012 - 02:46 pm
Posted 15 October 2012 - 03:01 pm
http://www.carpe-tdm...7855&hl=fusebox
Posted 16 October 2012 - 07:25 am
might take it off and inspect later, could add a fuse for Sat Nav and phone charger too then!
the new starter unit should be here today so will keep posted.
Edited by lparker, 16 October 2012 - 07:27 am.
Posted 16 October 2012 - 04:51 pm
Good Luck
Posted 18 October 2012 - 08:41 pm
didn't wicky do a write up on cleaning a starter solenoid
aye i did indeed. ya don't need to 'cut the top off the solenoid' as the unit simply comes apart ! if you carefully look at it you'll see how i did it. Personally i disconnect the battery and inspect / flush out the fuse box with brake cleaner, dry it off with d'air line and re-apply ACF50 as required.
Posted 18 October 2012 - 08:59 pm
Posted 18 October 2012 - 09:09 pm
Edited by hammerman, 18 October 2012 - 09:09 pm.
