just done a filter change on my 98 import and after putting in about 1.5 litres of oil the oil level sight glass was nearly full but the manual says it should take 3.8 litres , as this is first dry sumped bike i've owned i thought i'd check and ask you lot
Oil Level
Posted 14 June 2013 - 04:50 pm
Posted 14 June 2013 - 04:53 pm
did you remove BOTH drain plugs?
Posted 14 June 2013 - 04:55 pm
theres 2
Posted 14 June 2013 - 06:02 pm
theres 2
You won't laugh when you realise that it is physically impossible to put 3.8 litres of fresh oil back into your engine via the upper tank without running the engine first for a short while.
This will become apparent as you wonder why the last half litre of oil is running across your cam cover, spark plugs and pooling nicely down there on your driveway.
I don't know why either.
Keep the last 0.5 litres back, run the engine for a couple of minutes first and resume.
Posted 14 June 2013 - 06:31 pm
ran the engine for a few mins to fill the oil filter and i got another half litre in , so thats 2 litres in total and its on the max line
Posted 14 June 2013 - 06:36 pm
Which suggests you haven't drained out all the old stuff.
The true oil level can't be determined until you've taken the bike for a 5 minute spin around the block.
F**king weird I know. Twists my bollocks too.
Posted 14 June 2013 - 06:43 pm
took the sump plug out then took the filter cover off , there didn't look much when i drained it , but i aint measure it to see how much there is but the wife wont let me have the jug out of the kitchen
Posted 14 June 2013 - 06:46 pm
The other sump plug is the bolt that screws in vertically, directly behind the filter plate.
Don't remove it now unless you'll be wanting to dropthe entire contents of the upper tank.
Posted 15 June 2013 - 04:57 am
theres 2
Yup, there are - one is a 12mm (or something) vertical bung on/in the filter housing, the other is a 15mm (or something) horizontal sump bung on the bottom left hand side of the engine.
Posted 15 June 2013 - 09:12 am
well i just measured what i took out of it and its 2litres
Posted 15 June 2013 - 11:20 am
drained all the oil out again , refilled it , ran it topped it up , ran it again , all good on the oil level mark
helmet on , quick 3 mile spin , checked the level after a brew and a smoke and its all good
but its still only 2l of oil in it
rang all me mates and asked them , they aint got a clue either
gonna be a bit paranoid bout my oil level for a bit now and i might even carry a litre with me on the bike just in case but until proven otherwise i'm gonna have to accept that it only takes 2l of oil
Posted 15 June 2013 - 04:29 pm
Welcome to the joys of MK2 ownership
Posted 15 June 2013 - 06:26 pm
Well there's this post http://www.carpe-tdm...=28049&p=275676 , worth reading.
But don't worry, at least "I've got your number" now.
Posted 15 June 2013 - 08:06 pm
Sounds like you left a couple of litres in there by only draining off one of the 2 drain plugs. In effect only doing half an oil change.
#16
Posted 16 June 2013 - 06:25 am
ok i'm getting confused here , is there a drain plug in the filter housing ? if there is and the filter housing is removed for a filter change aswell as the sump plug all the oil should come out or is there another bloody plug somewhere else ?
#17
Posted 16 June 2013 - 07:22 am
there is a sump plug on the stand side , theres also a bolt a long one near the oil filter cover which drains from above im going to get one of mr hentys oil pressure thingys with light .
#18
Posted 16 June 2013 - 07:42 am
ok i'm an ass who should be slapped repeatedly with a hammer , might knock some sense into me
i reread the book properly instead of reading it upside down trying to service the bike
there is indeedy another plug and i did do half an oil change oh the shame
#19
Posted 16 June 2013 - 08:40 am
We did try to tell you
#20
Posted 16 June 2013 - 09:32 am
Well folks that's the first stage of his 'initiation' into Mk2 ownership passed. Well done that man.
Should we get him to try and change the battery now?
