Getting the TDM onto a paddock stand
Posted 12 April 2008 - 08:57 pm
Think I might go back to the 'crate and brick' method.
Didn't realise how bloody heavy the TDM is...
Should have got an ABBA stand, but will have to save up for that.
#2 Guest_Catteeclan_*
Posted 12 April 2008 - 09:02 pm
Save for the abba, crackin bit of kit.
Posted 12 April 2008 - 09:59 pm
To take the bike off, I usually lift the paddocks's end a little, put my foot under it, grasp those passenger-handles, kick stand up all the way with my foot and end up holding the bike safely in my hands; if you had made sure the side stand was out, you can simple put it on there.
I use cheap paddock stands, I paid less than £30 for the pair on eBay 3 years ago and they've been excellent. The Buell has been on them for 7 months in the garden when the front engine mount had snapped, and no fatigue or rust whatsoever. Sometimes cheap is all you need
Edited by robelst, 12 April 2008 - 10:03 pm.
Posted 12 April 2008 - 10:19 pm
Just don't forget the sidestand when you put the bike back down!
Posted 13 April 2008 - 05:43 am
It's actually harder to set up on the ABBA stand than a paddock stand - the benefit is that they're more versatile because of the higher lift and the ability to lift the front end easily. I use the paddock stand for chain service and the ABBA when I want to clean underneath or work on the front end.
The trick is to get it correctly positioned and hold the bike plumb before you start lifting. Also, the angle you push the handle down at should be perpendicular to the rails ( ); by that, I mean push down & backwards a bit, not straight down.
Posted 13 April 2008 - 08:57 am
Agreed
2004 Triumph Speed Triple
2006 Honda Dylan (I know but I don't care when it gets dirty, dropped or stolen)
Gone but not forgotten
2006 TDM900A. Airbox mod (thanks JBX), Fuel cans, Safety lights, Garmin GPS,
2003 TDM900. As above.
Posted 14 April 2008 - 12:23 am
#8 Guest_Hughie tdm_*
Posted 14 April 2008 - 06:48 am
Use a stand I bought at auto jumble at Rufforth fits similar to Abba stand but over footrests not swinging arm pivots. no compression on back end easy to one man operate but still a little heavy on front end.Pretty cheap too about £45 if I remember
Posted 15 April 2008 - 12:06 pm
Posted 15 April 2008 - 12:53 pm
Posted 15 April 2008 - 03:59 pm
Sorry mate but I think the Abba stand is easy to use wether its cos I'm so tall but I can get my TDM up on the Abba in prob less than 2mins, But I can reach over and the bike to put the other side on and do up the bolts then just lift it up
Have used paddock stands on other bike and found them a complete pain in the butt. I would never buy one again:tdown:
My Super Modded TDM has gone to a new home
Posted 15 April 2008 - 04:11 pm
i always put the bike in gear and line up the front wheel straight
put the paddock stand to approx where the bike will be once you stand it up straight
use the grabrail or similar with one hand (i use the givi top box as it gives extra leverage)
the other hand on the paddock stand and it just seems to work
Posted 15 April 2008 - 04:13 pm
Remember yer first ride - and then things improved............
Posted 15 April 2008 - 07:47 pm
Mind your fingers !!
It's safer with the engine off.
Posted 15 April 2008 - 08:24 pm
Nothing like a healthy bit of competition!!!
I have been practising for about 30 minutes this evening and I have nearly got the hang of it now. Have got the balancing the bike upright bit sussed, I just need to synchronize the 'lift the back of the bike whilst pressing down with foot on the handle of the stand" My feet and brain seem to operate on different wavelengths these days..
Galilee - he makes it look so simple, I think I might weld a handle on the stand if it makes it THAT easy
Edited by brightonTDM, 15 April 2008 - 08:25 pm.
#17
Posted 15 April 2008 - 08:46 pm
That's OK, JG. I can also set up me ABBA stand in under 2 mins...........but I can put it on the paddock stand in under 20 seconds!
Just get the cups in the right place under the swinger and up she goes!
Your height is definitely to your advantage; I can't reach over the bike to the clamp at floor level without losing it. So I have to get on it, fasten up, then somehow keep it upright while I get off again. It's a right kerfuffle! But I still like me ABBA, they're a great piece of kit.
Edited by Sparky, 15 April 2008 - 08:48 pm.
#18
Posted 15 April 2008 - 10:33 pm
#19
Posted 16 April 2008 - 08:30 am
Once you've got weight on the cups you don't need to support the bike and can transfer your efforts to the stand. I always lift mine from the right, so if it does ever manage to get away from me it drops back down on the sidestand. Once the bikes vertical it only needs a hand on the givi rack to keep it ballanced, and a knee by the pillion footpeg in case it starts to come towards me, leaving my left hand to position the stand.
#20
Posted 16 April 2008 - 05:19 pm
Will have to re-route my Scottoiler hose though as I found the L/H cup clouts the sprocket nuts.
