Off down South in the morning to Steve Jordan's in Great Bookham. Time to get the bike dyno done at last and get the suspension sorted. Don't know why but ever since I changed the tail-pipes the front end has been ridiculously light!
Posted 07 September 2015 - 05:43 pm
Posted 07 September 2015 - 07:21 pm
Be very interested to hear your results.
Posted 07 September 2015 - 08:55 pm
Posted 08 September 2015 - 07:47 am
Posted 08 September 2015 - 04:32 pm
What a ride today! Nice blast to Surrey and back.
So...The suspension set-up bit, What an amazing difference!! The moment I sat on the bike after it was done it felt like a spine had been inserted under the seat. You don't realise how baggy, sloppy and bouncy your bike is in default set-up until you get someone to sort it. Now true, it did feel rock hard and a bit unsettling... for the first corner! But after that it just felt...well, proper. Instead of dropping into unseen potholes (Road near me, don't worry I go past it everyday...just forgot this time!) you kinda fly over them. Bumps on the M1 are passed over in a smooth strong way. And the feeling that the seat is actually there to support you is a very nice surprise.
£65 well spent and would recommend everyone does it.
Hhmm...The Dyno bit. Now I'm no speed freak so explaining this might be a little vague. The chap that did it showed me the before and after sheets and explained that the bike had been quite lean at low revs. He also said that the mid-throttle had been smoothed out. He also recommended a Power Commander. But to me riding home the bike felt worlds smoother at all revs. Leaving it in gear longer actually felt like the right thing to do, which is probably me anyway, I always change up too soon! Changing down was a huge surprise. I didn't get that lurch forward and roar of revs. Just a smooth purr of revs. NOW THIS COULD JUST BE MY RIDING!!! Let me know if it is
£40 spent wisely too,
Now the Power Commander. I know a lot of you chaps have one, and I appreciate the chaps at Steve Jordan's recommending one. But they quoted a price of £580 for one fitted. Do I actually need one? Is it truly worth the expense? Am I even near good enough a rider to get anything out of one?!?!
But apart from that it was a great experience. The staff are all welcoming and the aura of confidence and competence fills every nook and cranny. I will be going back there from now on, for everything from a service, to MOTs and especially when its time for the Nitron and Gold valves!!
Posted 08 September 2015 - 07:26 pm
Edited by celticbiker, 08 September 2015 - 07:26 pm.
Posted 09 September 2015 - 08:31 am
I can recommend Steve Jordan as well having used them last year for a Power Commander map on the new bike - I'm not sure one is really worth it if you have stock cans but with after markets it certainly makes a difference.
I also had the suspension set up at the same time and although it made a difference it's nothing like now. A couple of weeks ago I had a nitron shock fitted and the forks refurbed with Hagon springs here - http://www.hmracing....sis-suspension/ and the difference is amazing.
I would happily have used Steve Jordan for this but HM Racing are within walking distance of me although they don't open weekends so I had to take a day off work. I would recommend them as much as Steve Jordan and they also do Dyno runs and Power Commander maps, the problem is they are racing most weekends so it's only midweek opening.
Posted 09 September 2015 - 08:33 am
Second hand PC3's go for around 130.00, mapping inc vat is around 200.00 max, I use HM Racing or Dynatech in Tadley. Fitting is easy on the TDM half hour at most, not including any other mods that may also improve the bike.
As for suss setup only so much can be done with stock gear as Celtic points out, tbh if you can't do basic sag and setup yourself then the moneys well spent, I often feel that 65 notes is a lot for a basic count off and measure up but workshops have to cover costs.
Imo mapping (PC3) does sort things out, but make sure you have done all your mods or you will spoil it later on should you do air box mod etc, I removed the lambda, airbox flapper and added my cans then mapped it. Bike is smooth from bottom end through the range.
I am guessing that they tweaked the CO values? We could not achieve much at all with the CO values in regards to mapping, the only way to map the range is with a PC3. Upping the idle speed helps with lurch when downshifting.
It is also possible to map both cylinders on the TDM with a PC3 however you will need sensor/probe points on both headers.
Edited by arthurbikemad, 09 September 2015 - 08:34 am.
Posted 09 September 2015 - 01:26 pm
I did this very thing a few days before. Hadn't ridden the bike since so I reckon it is the higher idle speed. I set it at 1,400 but turned it down a frac to approx. 1,300.
Still contemplating fitting a power commander but if I'm honest, the Nitron shock and gold valves are first in line when it comes to £600 or so!
Posted 10 September 2015 - 07:54 am
I think thats a wise move, if you added the PC3 (you may get a S/H one in time) you'd have the best setup poss. I am tempted to drill and weld in sensor points to both headers and see how far out mine is, a clue is the bluing on one of my headers is somewhat longer than the other but prob down to the fact she was so lean before mapping.
Posted 10 September 2015 - 08:46 am
Posted 10 September 2015 - 06:19 pm
A power commander seems to be the way to go. May be pricey but I have no intention of ever selling the bike, so years of use seem to justify the outlay. Quite fancy getting it all done on the same day, power commander, gold valves and Nitron!!
Amazing how the suspension can feel so different in such a short time.
