Electrical Fail
7 replies to this topic
#1 Doggy
Doggy
  • 379 posts
Posted 16 March 2024 - 03:26 pm
Hi All
I disconnected my satnav from the battery and reconnected the bikes battery leads.
On pressing the starter there was a fizzing sound and now everything is dead.
Is it the green 40amp fuse blown?
How can i check it?
Where can i get one?
Any other suggestions?
Doggy
#2 trevini
trevini
  • 1,781 posts
Posted 16 March 2024 - 03:47 pm
I'm guessing you've left a lead disconnected when you reconnected the battery cables. Easily done.
2004 Galaxy Blue. Owned since 486 miles.Renthal 755 bars, Bagster tank cover, Oxford heated grips, DL650 hand guards, Double Bubble screen, Scorpion Rad guard, Gel pad insert, HLD undertray, Angry Badger tailtidy,  Michelin Road 5s, Givi E21s, E46 topbox, Ohlins shock and YSS cartridge emulators   Currently not fitted - PC3, Remus Revolutions.
#3 drewpy
  • 1,759 posts
Posted 16 March 2024 - 03:48 pm
https://www.halfords...nEaAt2PEALw_wcB
get some anyway, if you've blown the big fuse
#4 Doggy
Doggy
  • 379 posts
Posted 16 March 2024 - 03:50 pm
Thanks guys, i will have another look,
#5 leehenty
  • 5,093 posts
Posted 16 March 2024 - 08:41 pm
The big green fuse is a J type https://www.halfords...215-705110.html
#6 Doggy
Doggy
  • 379 posts
Posted 18 March 2024 - 12:25 pm
Now sorted, big green fuse gone. £4.50 now all good. Thanks again.
#7 leehenty
  • 5,093 posts
Posted 18 March 2024 - 09:25 pm
£4.50 each 😲🤪
#8 drewpy
  • 1,759 posts
Posted 18 March 2024 - 09:37 pm
£4.50 each
or pay an electrician £64.50 :)
