Water Pump (9Ner) -Oil Leakage
Posted 30 August 2015 - 09:16 am
Just discovered small oil leakage originating from water pump. I was advised by my mechanic that the leakage is due to a faulty oil seal. He tried to fix it but says he could not stabilize it in place and the seal keeps dislodging. Suggested we change the complete pump...
Has anyone been through this kind of situation? any advice?
My bike has 60000Kms on the odometer...
Danresh
Posted 30 August 2015 - 09:32 am
Lee Henty has successfully repaired a pump. http://www.carpe-tdm...hl=+water +pump
If it's the outer seal then it's pretty straightforward replacing it with a new seal.
Posted 30 August 2015 - 01:08 pm
We tested the bike - running the engine inside the workshop and then riding it for some distance using a lot of throttle changes.
No oil leakage detected..
Will follow up with frequent visual checks. If I discover renewed leakage, will order new pump.
Danresh
Posted 30 August 2015 - 01:54 pm
Posted 30 August 2015 - 04:58 pm
Now I just fly everywhere.
Gone to new owner.
Black Mk2a
