Interesting, For The Mechanic At Heart
Penetrating oil
18 replies to this topic
#1 Retro
Retro
  • 242 posts
Posted 09 September 2014 - 09:17 am
The American Machinist's Workshop Mag published some information on various penetrating oils. The magazine reports they tested penetrates for break out torque on rusted nuts. They arranged a subjective test of all the popular penetrates with the control being the torque required to remove the nut from a "scientifically rusted" environment.
(Average torque load to loosen)
No Oil used ................... 516 pounds
WD-40 .......................... 238 pounds
PB Blaster ..................... 214 pounds
Liquid Wrench ...............127 pounds
Kano Kroil .................... 106 pounds
ATF-Acetone mix...........53 pounds
The ATF-Acetone mix is a "home brew" mix of 50 - 50 automatic transmission fluid and acetone. Note this "home brew" released bolts better than any commercial product in this one particular test.
ATF-Acetone mix is best, but you can also use ATF and lacquer thinner in a 50-50 mix.
#2 dapleb
  • 18,118 posts
Posted 09 September 2014 - 09:24 am
http://www.carpe-tdm...7080&hl=acetone
#3 chrisr
  • 1,746 posts
Posted 09 September 2014 - 11:22 am
Does the ATF acetone mix damage paintwork or plastic?
#4 wigwamclan
wigwamclan
  • 200 posts
Posted 09 September 2014 - 11:24 am
Are there any stats for PlusGas?......it seems to work well enough
#5 TYREDNGRUMPEE
TYREDNGRUMPEE
  • 1,627 posts
Posted 09 September 2014 - 06:14 pm
Where would you source Acetone from?
#6 ChrisG
  • 8,276 posts
Posted 09 September 2014 - 06:24 pm
Nail varnish remover, although you can probably buy it cheaper online.
Be very careful around plastics though, someone on here posted something about doing faring repairs by melting lego in acetone and using it as a filler.
#7 TDMick
Posted 09 September 2014 - 08:39 pm
You can get acetone from a chemist IIRC.
#8 RogerD
RogerD
  • 241 posts
Posted 09 September 2014 - 09:25 pm
You used to be able to source it from boat chandlers about 5yrs back. i have had no reason to buy any since then , but recon they probably still sell it.
Roger
2004 Silver TDM 900, Scorpion cans, MRA screen, Heated Grips, Piramid Fender Extenda. Mitchelin PR3's, Oxford Soft luggage.  Now living with Sidestand
#9 Studley Ramrod
  • 19,214 posts
Posted 10 September 2014 - 08:27 am
Tesco pharmacy, quid a bottle. :)
#10 TYREDNGRUMPEE
TYREDNGRUMPEE
  • 1,627 posts
Posted 10 September 2014 - 09:02 am
That's a cracking idea. Two new tricks.
Thanks everlybluddy.
#11 TinTin
TinTin
  • 1,296 posts
Posted 10 September 2014 - 05:12 pm
Acetone also cleaned the brown staining on my KH250 carbs & made them look like new. Showing my age :bag:
#12 stu
stu
  • 2,060 posts
Posted 10 September 2014 - 05:53 pm
Did it do the seat too ? ;D
#13 TinTin
TinTin
  • 1,296 posts
Posted 11 September 2014 - 07:31 am
No. Needed flash & a scrubbing brush for that.
In the wet it would go on to 2 cylinders when I shut off approaching a bend and back on to 3 half way round. :rant:
Saw a lads 500 do the same doing a u turn in the street. Crazy days :blink:
#14 EeeTea
EeeTea
  • 87 posts
Posted 24 September 2014 - 05:10 pm
Retro - thanks for posting  :drinks:
#15 jlmtdm
jlmtdm
  • 500 posts
Posted 25 September 2014 - 05:38 am
I have just got a gallon of acetone to clean the varnish out of the brick tank.
Will strip any paint it touches .
#16 TYREDNGRUMPEE
TYREDNGRUMPEE
  • 1,627 posts
Posted 01 December 2014 - 06:39 pm
Can't wait to try this out.
Boots the Chemist, Acetone £1.59 + 1 x dropper bottle £1.00.
Spare ATF from carb balancer setup. 50/50
#17 Gasman
Gasman
  • 483 posts
Posted 01 December 2014 - 06:43 pm
Sorry for the dumbness
What's ATF?
Ta!
#18 Rallyist
  • 3,253 posts
Posted 01 December 2014 - 06:56 pm
Automatic Transmission Fluid.
#19 Limbo
Limbo
  • 486 posts
Posted 03 December 2014 - 12:03 pm
Right.
It is a very fluid oil.
You can use also hydraulic oil or oil for the motorcycle fork.
We use hydraulic oil for the excavators in the motorcycle fork.
Good tip.
So far I used WD40 or other penetrating oil and heated the outer thread.
So that oil is better penetrate into the smallest joints can.
Limbo
