We're under house arrest here, again ! For at least a month, so I decided now was the time to do something about the seized damper adjusters on my 1991 TDM 850.
And I thought, while I'm at it, I might as well replace the bushings and fork seals. So ordered the stuff up from Wemoto.fr and made a start first thing this morning.
Firstly, I tackled the damper adjusters by Dremelling ( is that a word ? it ought to be ...) out the pressed in washers at the top and finding that the adjustment wasn't equal. One adjuster was right out, up against the circlip, and the other one looks as if its wound right in.
Dapleb has put some excellent posts on here about this. To be honest, I don't think I would have tackled this job without them.
So both adjusters are steeping in penetrating fluid overnight and tomorrow I'll attempt to separate them and refurbish the detent springs and balls, using heat if necessary.
[attachment=13801:Electric Impact Wrench.jpg]
Next it was removing the bottom bolt holding in the damper tube. This, I've been well warned, can be stubborn. I secured one of the fork legs onto my workbench and set about the bolt with a ferocious electric impact driver. Did it remove it ? Did it f*ck !!
OK. more super expensive penetrating fluid, then heat, then gave up and had a good sound fit of cursing. That seemed to help and while my blood was up I started very carefully drilling out the head of the allen bolt. Once I'd got a 10 mm drill hole the head snapped off easily and I could remove the damper tube.
I thought I was going to have a bit of a job getting the stub of the bolt out of the bottom of the damper but surprisingly I just ran it out with my fingers. No sign of Loctite ?
So why was the damn thing to tight ?
[attachment=13802:Drilled out Damper Bolt.jpg]
Then to remove the stanchion, bearing rings and seal. I tried the Haynes method but all I was going to do with that was end up with arms like Popeye ! Dapleb to the rescue again with an article he'd done about making up a threaded puller arrangement. I kind of modified his approach but the principle worked and I soon had the lot separated.
[attachment=13803:Dismantled Fork Leg.jpg]
That's the story so far. To be continued....
