Replace Handlebar Rubbers
Posted 02 March 2011 - 11:19 pm
If you aren't sure what I'm on about, the part is
3VD-23434-00-00 . HOLDER, DAMPER
on the parts fiche
Posted 02 March 2011 - 11:24 pm
My tip when fitting, get some alcohol liquid hand rub, lubricate when fitting, alcohol evaporates job done
Posted 02 March 2011 - 11:37 pm
If I can get away without them I can see a machining job for Leehenty on the horizon. Either that or I'll try to find some poly bushes that fit (seem to remember getting some hard bushes for a MK1 golf trailing arm a while back, they were only £15 for the pair posted).
Edited by hammerman, 02 March 2011 - 11:37 pm.
Posted 02 March 2011 - 11:42 pm
Lew
Posted 03 March 2011 - 12:46 am
Edited by leehenty, 03 March 2011 - 12:48 am.
Posted 03 March 2011 - 09:11 am
Posted 03 March 2011 - 09:37 am
Contemplated replacing mine on me mk1 but never got around to it.
You might be able to experiment with some wide washers so you get the same effect as not having rubber insert doohickeys
I'd say the mk1 has a more pronounced vibe than a mk2, dunno if the 270 crank makes a difference.
Posted 03 March 2011 - 03:39 pm
Post a picy of what they are supposed to look like , spring must be coming, you are all getting out there fettling
Posted 03 March 2011 - 04:27 pm
Posted 04 March 2011 - 01:03 am
Well if you want rid of the damper just turn up a bit of HE30 alloy bar to the right sizes, anyone got one they can take accurate measurements off ? Bore size, outside dia and the size and depth of the steps.
Posted 04 March 2011 - 08:13 am
I'm going to try and get them out this weekend, I'm hoping they aren't pressed in or put up a fight coming out. Unless anyone else has a Yoke off the bike with the dampers already out and they can measure the bore etc ?
Posted 06 March 2011 - 02:51 pm
Lee, I'd still like to make some solid replacements for the dampers, looking at the design the solid ones won't need the shoulders machining, so it'll be a straight cylinder with a hole drilled through it. I'll give you a shout when I decide to tackle this.
thanks
Posted 06 March 2011 - 05:10 pm
You just reminded me why I never bothered replacing mine They do look kinda permanent don't they !
Have to say, the design of the mk1 yoke is total crap, and why did they make em with lickle bumpy-boobs ? You can't fit 99% of the bar clamps/risers without 'em lookin' silly.
Posted 17 January 2021 - 02:38 pm
Lee did Hammerman ever get around to you for these bushes ?.?
