Reg Rec
Posted 18 November 2016 - 08:21 pm
Posted 19 November 2016 - 10:34 am
Posted 31 December 2020 - 12:28 am
Thread dredge but I have the same issue. At present I'm considering either
- drilling a hole in the top of a 10mm socket so I can get some leverage on it as no way wrench will fit on top.
- drilling out the bolt from the battery side
- cutting it off battery casing
Only other option is remove rear shock and that seems a tad excessive for what is a 5 minute job on any other bike I've owned.... there must be an easier way.
Does anyone know the "proper way" to get the rectifier off on a TDM900?
Posted 31 December 2020 - 11:21 am
Does the workshop manual reveal any clues?
Posted 31 December 2020 - 01:09 pm
Howzabout a heavily offset ring spanner, like this:-
https://www.google.c...QMygAegUIARDsAg
ADD: The above fits - using my 10 & 11 mm size.
I also fitted a combination 10mm spanner with a mild offset - less offset even than this: https://www.amazon.c...E/dp/B01BOT028K
I suggest you douse the bolt in penetrating fluid first - it gets manky and wet under there.
Edited by steve27bha, 31 December 2020 - 06:27 pm.
Posted 31 December 2020 - 01:30 pm
- or one of these with a 1/4" socket:-
https://www.tengtool...x-Wrench-691406
Mine with a 12mm socket on the end needs a 44mm clearance. My socket is shorter than that illustrated and from a cheepo set.
- wrench must have been cheaper when I bought it tho'! (ADD: mine is an earlier design, less streamlined and without the hole)
ADD LATER: This does NOT work even with the correct 10mm socket - too little headroom.
Edited by steve27bha, 31 December 2020 - 06:28 pm.
