My New To Me Tdm 850 1995
Posted 16 January 2021 - 04:57 pm
So if you see a small mushroom cloud over Gloucester you'll know it's gone tits
Posted 16 January 2021 - 09:14 pm
it's not so bad, can go swimmingly smooth or a bit frustrating, best thing you can do is cable tie the sprocks to the chain before moving if needed, good luck
Remember if replacing shims you'll only be able to get em in increments of 5 so plan accordingly..
Posted 17 January 2021 - 07:09 pm
Plenty of help on here esp. where tits are concerned just shout out if you get any problems.
Posted 18 January 2021 - 05:01 pm
esp. where tits are concernedjust shout out if you get any problems.
or is it... plenty of tits on here esp. where help is concerned
As Cliff says, firmly cable tie the chain to the cam sprockets if you need to remove the cams. Makes reassembly and subsequent cam timing much easier.
Edited by Jim, 18 January 2021 - 05:05 pm.
84 Honda XL600R
04 TDM900
21 KTM 790 Adventure
Posted 18 January 2021 - 07:05 pm
Posted 18 January 2021 - 11:00 pm
It all came apart. Think it was looked after before, hopefully. Now I have poor old thing.
I'm in Gloucester anybody close. Just curious.
Had a bit of banter off the guys on the VTR forum. But it's all good fun, mind you I have given a bit out in the past
Ohh btw sprokects and cam chain cable tied together. Fingers crossed 🤞☺️.
No wonder garaged avoid, lie or charge ott prices. Thankfully I am not against the clock
Edited by Dickiebig, 18 January 2021 - 10:57 pm.
Posted 18 January 2021 - 11:05 pm
I did manage a tour of Dumfries with the boys but my joint were f@@k@d for two weeks after!!!
Posted 19 January 2021 - 01:46 pm
Posted 19 January 2021 - 05:06 pm
Posted 20 January 2021 - 07:54 pm
The oddly numbers shims were probably factory fitted. Either the valves haven’t tightened up or a previous owner shifted them around to get the correct clearance on a previous service.
Edited by Jim, 20 January 2021 - 07:55 pm.
84 Honda XL600R
04 TDM900
Posted 21 January 2021 - 12:40 am
Treated myself to some heaters grips to so will fit them.
All ok waiting on shims
Posted 21 January 2021 - 09:02 am
I've seen odd numbered shims on ebay, didn't a dirt bike have the same shims?
Posted 21 January 2021 - 09:19 am
I would imagine there are quite a few engines using the same size shims, it'd be a hell of an outlay to use odd sizes for one engine type especially when there's so many size options to stock.
The odd numbered ones on ebay would likely be originals that have been swapped or bikeshop stock sell off.
Posted 21 January 2021 - 05:18 pm
Got my new shims oft the Dirtbikestore on ebay, good price, I think, and quick delivery. Just waiting on the shims for the inlet side now
