Clutch Noise Scream Squeal
#21
Posted 20 June 2012 - 10:38 am
We have been getting this all wrong apparently this is a chractaristic - Its supposed to do this!!!!!! Funny I dont remember seeing this in the sales brouchure!!!!
I think it is time for ALL TDM owners to email cutomer services as below and remind them that this "charactaristic" was not in the sales brouchure and therefore does not form part of the sales contract!!
Amazin - im gonna send this one to the BBC me thinks share it with the world and let them have a laugh too....
For the Attention of Ronnie,
Thank you for your email, in relation to the clutch on your Yamaha TDM900 the details of which have been noted, for our files.
We have in this instance referred the contents of your email to our Technical staff, who have been in contact with Webbs Yamaha Centre, to discuss your concerns.
Subsequently, we can advise that the phenomenon you describe, is possibly that which is generally in keeping with other examples of your model of TDM900. As such, we would consider this to be a characteristic of this model, rather than related to any particular fault.
In view of the above, we would advise that the factory consider that no remedial action, is necessary.
However, should the symptoms change, we would kindly suggest that you re-establish contact with Webbs Yamaha Centre to further inspect you machine. They will then be in a position to report their findings to our Technical staff, for any appropriate advice and assistance.
We thank you for your enquiry and based on the above information, trust that you will have no further cause for concern.
Regards,
Customer Service
Service Department
After Sales Division
___________________________________________________
Y A M A H A M O T O R ( U K ) L T D
Sopwith Drive
Brooklands
Weybridge
Surrey KT13 0UZ
Telephone:
Fax:
E-mail:
Website: +44 (0) 1932 358000
+44 (0) 1932 358030
cust.service@yamaha-motor.co.uk
www.yamaha-motor.co.uk
#22
Posted 20 June 2012 - 10:41 am
don't know how to get rid of it, new oil certainly makes is less likely, but I'm out of ideas
I'm really not sure what you're saying. Are you saying that when you used Lidl oil the problem disappeared, or that it didn't make a difference. I found that the high end expensive oils I used produced clutch slip and the cheaper oils I used didn't. I'm no oil expert, but maybe the sticky efficiency of the better oils cause the plates to slip and the plates fling off the humble oils quicker
Gorn
#23
Posted 20 June 2012 - 12:47 pm
#24
Posted 20 June 2012 - 12:58 pm
Tends only to be in the 1st couple of miles of a journey, and more so when it's coming due an oil change...
Having seen this conversation on more than one occasion I don't think there is any one thing that you can put it down to.
As QM said about the Ducati clutch "chatter", the squeal is just part of the TDM "character"
#25
Posted 20 June 2012 - 07:46 pm
#26
Posted 21 June 2012 - 06:50 pm
Dear Mr Manley,
I am very grateful for your response however I can only conclude that you have neither ridden a TDM or owned a TDM with this problem. This is no “characteristic” as you suggest, this is a VERY loud scream when putting the clutch under any kind of load which is slightly greater than a very gently application. I cannot believe that Yamaha would design in this characteristic – it’s just ridiculous if not laughable to suggest that Yamaha would do this! It is certainly not a “characteristic” which I have seen in any sales brochure!
I have been conducting research to this problem starting with a post on CARPE-TDM owners message board (www.carpe-tdm.net). Within a few short hours there were many posts with other users complaining of the same problem to varying degrees. For your information I have attached a print of a part of the thread.
I have also discovered that this problem is not unique to the TDM clutch, apparently your FZR750/100 and YZF100 have the same issues, I can only presume a similar clutch design as the TDM.
I have also discovered (Via CARPE-TDM) a web blog from a YZF1000 owner who has modified his clutch basket, basically by drilling a series of additional holes and channels to improve the oil flow over the friction plates (please see http://homepages.par...utch/clutch.htm or http://www.factorypr...h/clutch_y.html ). His modification resolved the issue completely. This action appears very drastic and beyond my capability, but I believe that he took this action after failing to get any kind of satisfaction from Yamaha. I believe this to be a very sad incitement to Yamahas commitment to the quality of their products and customer service.
Therefore I suggest to you that given the modification to the oil flow in the clutch basket appears to resolve the problem that this issue is indeed an inherent fault to the clutch basket design and not an acceptable characteristic as you suggest.
I have copied Tim the service manager at Webbs Peterborough in on this email in order to keep my local dealer abreast of our conversation.
I would be pleased to hear what investigations Yamaha propose to fully diagnose this inherent design fault, and what remedy Yamaha would offer.
Kind regards
Ronnie
Don.Manley@yamaha-motor.co.uk [mailto:Don.Manley@yamaha-motor.co.uk] On Behalf Of Cust.Service@yamaha-motor.co.uk
Edited by Ronnie, 21 June 2012 - 06:51 pm.
#27
Posted 21 June 2012 - 07:20 pm
#28
Posted 21 June 2012 - 07:33 pm
Ronnie, bought my 9'er with 23k on it, cold starts or when wifey on pillion caused same awful noise.
Dealer eventually replaced all friction plates AND SPRINGS, told that when friction plates fully bed in they can become "polished", and this causes resonation when on last friction slip before clutch engages.
So, me thinks the springs as well as the clutch plates adds the bit more pressure to resolve it.
Good luck!
#29
Posted 21 June 2012 - 08:38 pm
Good luck!
Thanks for comments - however new clutch plates and slings didn't help me resolve this 'charctaristic'.
#30
Posted 21 June 2012 - 09:01 pm
I'd complain to Yamaha 'bout that Dandy !
#31
Posted 27 June 2012 - 05:57 pm
Any ideas what I should do next???????
Thank you for your further email, regarding your Yamaha TDM900.
Unfortunately, we are unable to recommend any non-standard modifications, that have not been subject to any relevant testing procedures at the factory.
As previously advised, should the symptoms you describe change, our Technical Service Department are available to the staff at Webbs Yamaha Centre, if required.
We thank you for your enquiry and whilst we understand that you may again be disappointed with our response, trust that you may understand our position.
Regards,
Don Manley
Customer Service
Service Department
Sopwith Drive
Brooklands
Weybridge
Surrey KT13 0UZ
Telephone:
Fax:
E-mail:
+44 (0) 1932 358030
#32
Posted 27 June 2012 - 06:08 pm
#33
Posted 27 June 2012 - 06:18 pm
When you say you've changed the oil, what do you mean? Do you mean you've changed this AX7 stuff many times or you've tried different types and brands of oil?
Gorn
#34
Posted 27 June 2012 - 07:56 pm
Ive tried diffrent brands of oil too - currently this AX7 stuff..................
#35
Posted 27 June 2012 - 09:12 pm
I'm only saying, because my TDM is sensitive to certain oil. I've found I don't get any slip on using cheap semi-synth. And since I only do about 3k or less a year of gentlemanly riding and change oil yearly, cheap is win-win.
Gorn
#36
Posted 27 June 2012 - 09:26 pm
That said, it still does it at 35,000 miles, clutch plates are within tolerance (measured them a coupole of months ago) and it doesn't slip.
Yamaha clutches do seems like pants though!
#37
Posted 27 June 2012 - 10:30 pm
My Duc ST4's clutch made a lot more reckit, BMW boxers (esp the old airheads) are a bit clattery too when pulling the clutch.
I guess it all IS characteristic?
No worries - in ten years time we will all ride electric bikes and I bet you wish you'd hear a bit more mechanical noises instead of a monotonous whine.
#38
Posted 08 July 2012 - 09:17 pm
Either live with it,or set off like a girl (sorry Ladies)
Just remember that some folk out there are only alive because it's illegal to shoot the buggers.
SUCK, SQUEEZE, BANG, BLOW........... X2 ;-)
Red, XTZ 750 Super Tenere, Gone,
Blue XTZ 750 Super Tenere, Gone,
Black XTZ (850 4TX Engine) Super Tenere, Gone
Dark Blue, 3VD, Gone.
Gold/Yellow, 4TX Gone
2002 TDM 900, BLACK/Dark Blue, fender extender,Ollins progressive front springs,24 L.E.D. runing lights,H.I.D. lights,Bagalux tank cover + Bag, Tall/Flip screen,12v socket on dash + 1 under seat,Scottoiler,"JBX" air-box mod, GIVI engine bars,ram mount for G.P.S.Givi tube rack + 42 Ltr boxes,Givi 42 ltr topbox,48 L.E.D.additional brake light,Avon Storm Ultra 2's, DL hand gaurds,heated grips,outlet for heated gloves/clothing,Black Lambs wool/skin seat cover
#39
Posted 21 April 2013 - 03:42 pm
OK guys HOT NEWS!!! – I have fixed it!!!!!!!!! Solution = 1 x EBC HD Clutch Springs + 4L Halfords Finest 10 40 Semi Synth Lube + 1 X Sureflex Clutch Kit Including new steels! http://www.biketorqu...mahatdm900-0210 - Just completed the installation then took her out and PROPER ragged it – not a peep!! Not a cheap solution though, the Sureflex kit is about the £145 mark, but I guess it’s the high Kevlar content which sorts it out. This worked for me – hope it works for you too….
#40
Posted 21 April 2013 - 05:56 pm
