Posted 16 March 2014 - 07:23 pm
Chris R popped up today for a mini fettle.
Changed the rear disc bolts, but despite heating them and being very careful two of them decided to come out halfway and shear off. Time to deploy the drilling jig. Two M8 x 1.25 3D (24mm) long helicoils had to be fitted to the galled threads.
Front ones came out no bother. We moved on to fork seals and head bearings which were replaced with a taper bearing set.
Various rusty bolts were thrown in the bin and replaced with stainless.
The rear brake torque arm bolt was particularly offensive and was replaced with a machined stainless boss and cap screw which happened to be in the bits box.
Not many pics as Chris was so busy getting into it he forgot to take many
Chris brought a nice new stainless sprocket carrier and axle nuts with him, so he's slowly being converted.
Disc bolts are titanium front and rear
Edited by leehenty, 17 March 2014 - 02:49 pm.
