Steering Bearings, Torque Procedure ?
Posted 16 June 2016 - 11:37 pm
I have a notched c-spanner with 1/4" drive square to suit the castle nuts.... what is the correct torque procedure to use ?
Posted 17 June 2016 - 03:41 am
Posted 17 June 2016 - 06:40 am
Posted 17 June 2016 - 06:45 am
Posted 17 June 2016 - 08:07 am
Is it the same spec for a mk1 though !!!!
Posted 17 June 2016 - 08:46 am
Posted 17 June 2016 - 07:07 pm
Gotcha, knew it's same procedure, anyway mine is tweaked a bit more than 15nm after a couple hundred miles, just dont do up bassid tight
Posted 17 June 2016 - 09:18 pm
Looks likely I'll be replacing the steering bearings this weekend.
I made myself a C spanner to fit the 9er nut, with drive via a 14mm AF nut for a 1/2" torque wrench. You are welcome to borrow it.
DSC08371.JPG 131.41KB 2 downloads
Posted 17 June 2016 - 11:03 pm
Posted 18 June 2016 - 11:06 pm
Grabbed those lowers and had a shake. Whoa, almost pulled it off the jack. 😰
Not one iota of play.? Well, went for a ride, knocking as usual. Rather annoying. Thorw me a suggestion members. PDGabe😎
Posted 18 June 2016 - 11:10 pm
Posted 19 June 2016 - 12:12 am
Keep those ideas coming. Thanks everyone.
#16
Posted 19 June 2016 - 01:32 am
#17
Posted 19 June 2016 - 07:09 am
#19
Posted 20 June 2016 - 04:45 am
Back again. Got the old girl on the rack, front off the ground. Shook the snot out of it. Nothing. Ok, spun the front wheel, hit the brake, knack. Once again, spin, brake, knack. Hmmm, let's try reverse. Not as bad. Now, this old girl just turned 50k miles today. I'm guessing maybe the upper bushings in the sliders? Yea/nay? Everything is tight. Only does this while rolling, never during braking fast or slow. What do ya think.
I have had knocks in my bar mounts. part from that, many bikes suffer from knocking sounds when braking, have seen suggestions that the spring may be the source - hitting the tube inside. I have had a slight knock when braking (always, I think), but have got so used to it I'm not 100% sure it's still there
#20
Posted 20 June 2016 - 09:09 am
You need to remove the wheel and mudguard and grab each fork individually to check for wear to the bushes.
