I cannot track down the eleccy fuel pump mod that many of you have done, keep getting an error message saying "you don't have permission" and other such garbage, when I use the "search" (ha! theres a misnomer).
any links please?
Fuel pump mod .....
Started by
stormy
, Feb 04 2008 07:49 pm
5 replies to this topic
Posted 04 February 2008 - 07:49 pm
currently owned ....
Posted 04 February 2008 - 07:54 pm
QUOTE(stormy @ Mon 4th Feb 2008, 08:34 PM) <{POST_SNAPBACK}>
any links please?
any links please?
The 'view new posts' is considere a 'search', and you're only allowed 1 search every.....can't remember now.
Try wait a little and try searching again.
And, yea, I'm looking for the electric fuel pump mod too. For a 4TX (1996 MKII). Is it the R1 from the same year? Does the 'lectric fuel pump fix the 'hard to start after parking for some days' problem?
Posted 04 February 2008 - 08:21 pm
Posted 04 February 2008 - 08:59 pm
Thanks for that.
So, if I understand the thread correctly then, the following points should be right....
1 Use an R6 carb pump and not an injection one?
2 If using the above, no relay is needed, just a switched live for the pump power?
3 No overflow/overfeed pipe back to the tank is required (I only ask this cos my V Strom has a feed and return line to tank)
4 I need to reset the float heights lower by 2mm?
If peeps could answer those points I'd be grateful!
Mike
Mike
Posted 04 February 2008 - 09:11 pm
QUOTE(stormy @ Mon 4th Feb 2008, 08:44 PM) <{POST_SNAPBACK}>
Thanks for that.
Nope!! Use an R1 pump, inlet & outlet pipe ID is the same so no splicing pipes o'different diameters
and no you don't want the FI one cos that mounts integral to the tank IIRC
I used a relay and had fuse in power feed to pump, cost pence, and took no more time really (can do you photos & more info on install, pm me)
No (guessing VStrom is FI?? Know bugger all about stroms)
Yup, I had to to take into account extra bit of kPa from da leccy pump
Be grateful
Mike
Be grateful
Mike
Edited by jht, 04 February 2008 - 09:36 pm.
Posted 04 February 2008 - 10:53 pm
cheers!
