Hi
It's the second time this week that I've to adjust the clutch free play. It went from 1 cm to 2 cm. I've adjusted it, and two days later the same. The top and bottom adjusters are on the limit. I suspect it is the cable because the lever on the engine is not on the normal position with the clutch fully depressed, but I do not believe the cable is stretching.
Any thoughts about it?
