Vfr Forum Search
6 replies to this topic
#1 ferky
ferky
  • 32 posts
Posted 04 April 2020 - 04:10 pm
can anybody on here recommend a helpful vfr forum . I have been given a 1986 vfr750f but it has an electrical issue which I cant figure out so looking for a forum to try and find help , unless any of you guys can help at all
#2 oldman
oldman
  • 78 posts
Posted 04 April 2020 - 04:26 pm
vfr owners club uk
#3 ramo
ramo
  • 1,176 posts
Posted 04 April 2020 - 04:38 pm
https://vfr.bikersoracle.com/
#4 Oafski
Oafski
  • 141 posts
Posted 05 April 2020 - 11:50 am
You don't specify what the problem is but I recently had the Regulator/Rectifier fail on my 97 CB500 and it does seem to be a weak point on Hondas.
"No good deed goes unpunished"
"Lags Droopfinger" The Biking Viking
OCD- Old Coffin Dodger
#5 leehenty
  • 5,080 posts
Posted 06 April 2020 - 05:48 pm
Hope it's not stator, VFR's known for cooking them.
#6 Catteeclan
  • 2,433 posts
Posted 06 April 2020 - 07:10 pm
And CBRs and CBFs
#7 steve27bha
Posted 06 April 2020 - 09:13 pm
I've had two VFRs - a 1994 750 and a 2000 800. The 1986 model is the first year of VFRs - the 750FG. Check the underseat "Color Label" for this and the paint code.
Bikers Oracle is an excellent source of info and has a load of help in its members section. Pay the fee, familiarise yourself with the content, introduce yourself and ask away.
I'm steve27bha over there too, but now inactive.
My top tip is to get hold of a Honda shop manual as well as a Haynes, the latter particularly for the coloured wiring diagrams. 2nd is to get to know David Silver Spares for bits.
