Hello all,
First post by a new owner of a '92 TDM850 in Canada. It was an impulse purchase, I had never seen one before and had to have it!
I've put about 500kms on it so far, and cannot track down a VERY loud and annoying noise - which sounds like road noise from misaligned tires. It sounds like an old Honda 3 wheeler I had as a kid and would ride on the paved roads, with the accompanying howl of the off-road tires. You could hear me coming from half a mile away! I cannot tell if it is like that to bystanders on my TDM, but it sounds like it while riding.
The bike has 83k kms on it, and the service history is kinda sketchy. It needs the emulsion tubes replaced, valves shimmed and the cam chain and tensioner replaced. I changed the oil twice (it was pretty black) in 500 kms, replaced the front wheel bearings to eliminate the howl (no change), and lube the speedo cable and speedo drive unit.
The 'howl' starts up at 80km/h and stays present with clutch in or out, in any gear. It will howl away and gradually reduce in noise as I decelerate down to about 30km/h or less. The tires are 2 year old Michelins.
Could this be a problem with the output shaft/transmission? Rear wheel bearing? Suggestions?
Thanks all!
