Link Pipe Joint
Posted 03 October 2020 - 12:11 pm
Posted 03 October 2020 - 01:19 pm
You need some thin metal sheet Chris, had two of them the same place (Internally) when dismantling exhaust from nephew's bike..
Posted 03 October 2020 - 01:20 pm
A rectangular shim cut from a tin or aluminium can, inserted in the link entry and wrapped around the header end. Plus some exhaust paste.
Hold it in place on the header with a jubilee clip while getting the other bit over it, then tap it into position for neatness before tightening the clamp.
Maybe!
ADD: Great minds think alike / Fools seldom differ - you choose!
Edited by steve27bha, 03 October 2020 - 01:27 pm.
Posted 03 October 2020 - 04:20 pm
Posted 04 October 2020 - 07:20 am
I've tried the tin can method and whilst it worked for a good while, it got really rusty and eventually started crumbling to bits. It was a really thin piece of can though. Soooo, you may want to try using aluminium if you can get some.
It is possible to enlarge the downpipe tube using a special tool, or an exhaust place might be able to do it for you.
Posted 04 October 2020 - 09:46 am
Posted 04 October 2020 - 11:47 am
https://www.ebay.co....tm/111083884881
Posted 04 October 2020 - 11:53 am
Posted 04 October 2020 - 02:20 pm
It the right side thats loose on my delkevic cans, annoying , the tin can idea sounds good
Posted 05 October 2020 - 12:34 pm
.... Soooo, you may want to try using aluminium if you can get some........
Several soft drinks are in Al cans.
Or, try Al foil - the thicker turkey type should work better - cut into a strip and wound round to get the required thickness. It's probably too fragile for this job tho'.
Posted 05 October 2020 - 04:10 pm
A thin sheet of Stainless should sort it Chris..
Posted 05 October 2020 - 04:25 pm
+1 that's worked for me too
If I had one to hand, an ali foil roasting tray, or disposable barbecue tray type thicker foil
Posted 05 October 2020 - 04:42 pm
Posted 06 October 2020 - 09:53 am
You could file out the relief slots in the outer to allow for more closure around the inner pipe, this might require a smaller clamp if it reaches it's lower limit before firmly clamping or otherwise if you do go the metal sheet route you could consider some appropriately sized copper sheet. Easy to work with and very pliable.
https://www.ebay.co....uIAAOSwGBhaZeBj.
