Mk1 850 Not Start For First Time Ever!
Posted 25 June 2017 - 01:37 pm
The only thing that I have touched to do with electrickery since it last started was to remove the ecm plugs to take pic!!!!!! As far as I remember I plugged it back in. :-)
Elec rather than fuel me thinks. Off to do battle after a sangas!! If you have any ideas please shout!
Posted 25 June 2017 - 04:13 pm
Chortlin' at others ? Prolly my turn next.
Did you check for a spark ?
Posted 25 June 2017 - 04:37 pm
It is indeed electrical. No spark either cylinder. Single coil unit so could be that but since the only thing I have touched is the Brian black box thing I bet its that!!!!!!
Have removed coil. Read Heinz. Not sure what I am doin but might try and test is or prolly more wisely take it to someone who knows what they are doing.
Any suggestions on where to get a new coil unit if required? I dont want shOite so might have to pucker up for a yam wan!!!!!!!
Posted 25 June 2017 - 05:12 pm
Secondary wind 15.50
Within spec!!! Bum badgers.
Posted 25 June 2017 - 05:34 pm
Coincidences are my forte. I have often blamed someone/thing for something & been completely out of order doin it.
Have you tried the usuals ie. kill, clutch & side stand switches.
Then have a look at the plug you disconnected & see if all the wires & pins are like they ought to be.
I know I keep saying this but I had a coil that gave the correct 1 & 2 readings but broke down under load. that said it misfired rather than no sparky altogether.
If all that fails take it to Studleys & tell him that as an administrator it is his duty to fix it
Posted 25 June 2017 - 05:56 pm
All wires still in plugs. All pins fine. Wiggle when turning over makes no diff.
I would expect this coil to have a go at starting even if it was struggling under load?
Checked main and ignition fuses too. Both fine.
Posted 25 June 2017 - 06:14 pm
Posted 25 June 2017 - 06:48 pm
Want to swap black boxes? :-)
Posted 25 June 2017 - 07:04 pm
Ignition switch need a wiggle ?
Coil wire terminals ok ? Wiggle them too.
Tis indeed a strange coincidence with unplugging the Brian.
Posted 25 June 2017 - 07:26 pm
Coil wires look wirey but I have no idea if good/bad/average.
Posted 25 June 2017 - 07:41 pm
A few have had a similar problem with the ignition switch, think it might have been the 9'er wans but, switch ign on and everything works but no starty, wiggle a few times then starty.
Doubt it's the coil wire terminals if ya haven't touched them.
re: replacement coil. Cliff couldn't find a decent replacement coil, M&P do coils but no idea on the quality. Think original coil was Denso, but seem to remember reading somewhere that only Lucas do the dual coil now and they're not as good. Can ya still get a Yamaha one ? EDIT: Fowlers sell 'em but they're not cheap.
Posted 25 June 2017 - 07:47 pm
Ugh prince of darkness. . . . Oil ask yam aboot new coil, though pretty sure thats not the problemo! Edit. Whats the damage? I seem to recall 70 quid but that was a long time ago.
Posted 25 June 2017 - 07:55 pm
Yes, that's what happened to some 9'ers.
Yeah, around £70 chief. I'd also be surprised if it was the coil.
Posted 25 June 2017 - 08:13 pm
Posted 26 June 2017 - 06:31 am
#16
Posted 26 June 2017 - 09:28 am
You're welcome to send me your black box for testing on me mokeyboike Daps.
#17
Posted 26 June 2017 - 10:56 am
Ferry kind of ewe. B-)
#18
Posted 26 June 2017 - 12:24 pm
Hi
If you pay for lodging and transportation, can it be a service at the place where the boike is located?
From Brasil.............
Cheers!
Edited by Sidarta, 26 June 2017 - 12:25 pm.
Att
Sidarta
TDM850 ano 2001 Honda XLX 250 1988
Honda CB350 1972 e 1973
#19
Posted 26 June 2017 - 01:09 pm
Yes peas SR can you send me am addy and oil try and get it in the post this eve.
Addy sent.
Hi
Cheers!
Not sure if that would be the most economical way to fix a problem.
#20
Posted 26 June 2017 - 02:07 pm
Hi Studley!
Yes it's true. It would not be the most economical.
Regardless, it would be a pleasure to receive you in Brazil.
We would have parties.
Edited by Sidarta, 26 June 2017 - 02:11 pm.
Att
Sidarta
