900 Fork Tool
57 replies to this topic
#41 OldGit
OldGit
  • 133 posts
Posted 12 December 2012 - 10:34 am
Jono, that's this thread...
here's a pic of my car
Alright Brain, you don't like me, and I don't like you. But lets just do this, and I can get back to killing you with beer.
#42 leehenty
  • 5,085 posts
Posted 12 December 2012 - 04:56 pm
You were very lucky to walk away from that one with very little other than bruises, so now you do in and out the bluebells with the insurance companies.
Hope you are on the mend and the inlaw is feeling better.
#43 Stiggy
Stiggy
  • 125 posts
Posted 02 January 2013 - 10:40 am
Nick (Oldgit) have you managed to sort your forks yet?
I rode into work this morning (I do 500 miles a week commuting on my 900 :-o ) and found I had a boot covered in oil. The LHS fork seal has failed and so needs replacing.
If you're not going to get round to doing yours for a bit, could you post to me and I'll return? Needless to say I will have to get mine sorted quick as poss.
Chris
#44 leehenty
  • 5,085 posts
Posted 02 January 2013 - 05:05 pm
if one has gone do both at the same time, or you will be back quite soon doing the other one :)
Don't ask how I know this...
#45 jono49
jono49
  • 1,183 posts
Posted 03 January 2013 - 12:07 am
Chris
Where are you Stiggy? I have one at mine if you need it.......PM me your address, and you can P-Pal me postage once I find a suitable container for shipment :good:
#46 Stiggy
Stiggy
  • 125 posts
Posted 03 January 2013 - 01:18 pm
Hi Lee - I always replace seals in pairs :) Genuine parts, dust seals and spring washers ordered and incoming.
There was a split in the LHS dust seal. I imagine water/salt has got in and corroded the seal from above (this happened on my Beta trials bike a couple of months ago). As it's been so wet, I hadn't noticed it until yesterday when my boot started slipping on the gear lever from oil being blown off the forks onto my boot!
Hi Jono - PM sent :good:
Edited by Stiggy, 03 January 2013 - 01:22 pm.
#47 OldGit
OldGit
  • 133 posts
Posted 03 January 2013 - 01:37 pm
Hi I was planning on doing mine towards the tail end of next week, Chris are you sorted yet, or can you wait a couple of weeks?
#48 leehenty
  • 5,085 posts
Posted 03 January 2013 - 04:08 pm
Nick, everyone all recovered from the crunch in the cage ?
#49 OldGit
OldGit
  • 133 posts
Posted 03 January 2013 - 06:28 pm
Yeah not too bad thanks Lee. I'm just dealing with recovery / valuation and injury assesment type things now.
Nick
#50 jono49
jono49
  • 1,183 posts
Posted 13 January 2013 - 01:27 pm
I now have a package made for Shipping "The Tool"!!!! I don't know what Lee uses but i think this will do as a Re-usable package? I've still to take it to get weighed for postal costs, but should be this week! :good:
Edited by jono49, 13 January 2013 - 01:29 pm.
#51 leehenty
  • 5,085 posts
Posted 14 January 2013 - 12:06 pm
I just use a cardboard tube but when It comes back I'll make one like that,it looks like it will work great.
#52 Stiggy
Stiggy
  • 125 posts
Posted 14 January 2013 - 06:42 pm
Nick - sorted mine at the weekend. The hydraulic method worked to get the old ones out - so was no need to remove the damper. Biggest swine was getting the new seals fully seated! Need another tool for that job LOL :)
#53 OldGit
OldGit
  • 133 posts
Posted 15 January 2013 - 08:51 am
Glad to hear that - I still haven't got around to doing mine :sorry: MOT is at the end of the month so need to get my finger out soon :um:
#54 leehenty
  • 5,085 posts
Posted 15 January 2013 - 02:42 pm
get a heavy 75mm bit of steelbar or a heavy pipe say 100mm long and turn down the end to
fit in the fork leg.
In my case I used solid bar. Bore it 50mm Then make an acetal tube 50mm outer dia, 43mm internal dia to fit inside the steel to protect the fork stanchion as you slide it up and down. A photo of my tools that fit various forks using one 'pusher'. You can make ally or nylon stepped rings to press in the seal and bush etc.
The dimensions are variable by whatever you can lay your hands on material wise, but the important one is 43mm for the fork leg.
Edited by leehenty, 15 January 2013 - 02:53 pm.
#55 OldGit
OldGit
  • 133 posts
Posted 01 February 2013 - 02:53 pm
I've finished with the Fork Tool, amazingly my heavy handed approach to the job seems to have worked, who wants the tool next ?
#56 Luke
Luke
  • 271 posts
Posted 12 June 2018 - 09:47 pm
Hi,I know it's an old thread, but is the tool available. Tried the impacter and broom handle to no avail.
Luke
#57 Studley Ramrod
  • 19,213 posts
Posted 13 June 2018 - 09:02 am
I am the current keeper of said tool Luke.  PM me your address and I'll get it posted to you.
#58 Luke
Luke
  • 271 posts
Posted 13 June 2018 - 04:58 pm
Just seen the reply. Sorted, thanks.
