Battery connections are not part of your new loom so check em out, have you checked sidestand switch also, when you remove the starter it will dribble out so not much, no need to empty oil 1st just top up after..
Plenty of vids on you tube to check starter relay, does it click once or click click click click ?
What's the new loom you had made, a whole brand new wiring loom for the bike !
Wiring should be OK since had new loom made for it. And it had the same problem since i bought it.
Did interesting thing earlier whern i stalled it wouldn't let me restart even in neutral for a few seconds then it fired up?
I'm wandering if it may be starter relay??
Regarding oil leak when i remove starter motor do i need to drain engine oil first or is it just a bit of a drip??
Dont presume everthing is tickety boo
You still need to check the starter connection in the switch if your getting intermediate starts, you could be spending when you dont need to Grendel.
