Well I had a good day today. Lovely run up from Foix to Saint-Girons and then via back roads to just outside Bordeaux.
So "I got my mojo back"....whatever that means ! My grandson say that's what you say nowadays in situations like this....
Anyway, rather than using the back brake to scrub off speed, I've been trying to be more sensitive with the throttle and also using 3rd and even 2nd gear more. If I carefully roll back the throttle I can control the speed of entry to a roundabout or bend without dipping the front forks by using the front brakes. And then the trick is to open the throttle smoothly enough to accelerate away cleanly.
Like you say, practice, practice. practice.....
I would also suggest having a little more slack in your throttle and consciously encouraging yourself to open the throttle smoothly.
I have found that I have to concentrate all the time to get a smooth ride from my TDM 900. No bad thing I suppose but something of a surprise to me when I bought it.
Practice, practice, practice. The TDM is a little top heavy however I was able to do a 35k heavy traffic commute with little worry. Roundabouts and city traffic I use lower gears and keep above 3k. City riding I usually keep it in 2nd and 3rd.
The most striking difference between the MkI and the 9er is handling roundabouts; The MkI is more top heavy (maybe that's why it tends to oversteer), has a need for being pulled back up once you get it leaned.
That said, letting go off the bars (releasing any tension in arms) in tight corners at low speed makes things easier.
Drivetrain slack (& imprecise clutch, in my case) adds to difficulty level
I've recently replaced the rubber cush drive in the rear hub and that's made a BIG difference. I'm running the chain with an extra 10 mm free play from standard, I might put it back to 50mm free play and see how that works out.
Yesterday I took a road from Perpignan to Puigcerda through the eastern Pyrenees and my confidence took a severe knock. Some of the bloody bends were more like sections in the Scottish Six Day Trial ! And especially when Maw, Paw, and the weans in a base model Renault Clio blast past you at warp speed.....
However, all was made up today, I found roads that exactly suited my current level of motorcycling skill.
The fun's back in motorcycling, so much so that if I was a drinking man I would murder a shandy !
