Scottoiler Fitting
Posted 22 November 2014 - 03:23 pm
I tried simply pushing the scottoiler vacuum tube onto the now visable spigot:
I knew this would be tight, and its also incredibly fiddly to get at, but i just don't think it will fit. Should it do?
Posted 22 November 2014 - 03:45 pm
I am looking to fit my scottoiler, and through help from you lot here, have found the vacuum point on no.2 carb. Studley, you were right. The tube had been cut and blanked off just off the manifold, so why the tube wasn't where the heinz said it should be. This is the bit of tube:
Can you not remove the blank and then use the piece that is left as a socket to join the vac tube to the spigot on the carb.
Posted 22 November 2014 - 05:30 pm
Good point sir! Like this:
It was a sod to get on as the tube was prolly a sniff too small, but some boilibg water and a sniff of grease got it to this stage. Do you reckon a teeny jubbly would be needed as well, or should that hold well enough?
The bit of insulation tape was because there was a tiny teeny lil hole in that tube. I mean, bicycle tyre puncture small.
Posted 22 November 2014 - 05:36 pm
I wouldn't think a clip is required as the vacuum isn't great from the manifold.
You also could have removed the elbow and just pushed in the pipe.
I'm a gasman and plumber so used to bodging things especially with pipes.
Posted 22 November 2014 - 05:46 pm
Excellent stuff. Cheers muchly!
I did think about removing elbow and doing it that way, but the vac tube on the scottie would have been too small for that. Now got to fathom where to put the rmv. Not many options. I think it was Studley that said he put his next to the rear master cyclinder. Dont know how though. Studley..Help!
Posted 27 May 2017 - 09:16 am
reviving an old thread
anyone have any insight where to put the Reservoir tube?
any photos?
Posted 27 May 2017 - 03:25 pm
On the 9r mine used to be on the rear hanger exhaust bolt using an alu extension piece..also had it under the left outside of the grabrail at one time.
Posted 27 May 2017 - 05:15 pm
I have an 850 4tx '96
Posted 27 May 2017 - 07:51 pm
Yea i know, you still have rear hangers and a grabrail on a 4tx, just trying to be helpful fella, further more i doubt there is much space under the seat unlike the 9r which is where most oilers get fitted, so barring those 2 ideas ANYONE ELSE got a oiler fitted to a mk2.
Posted 27 May 2017 - 10:08 pm
You can put them under the seat on a Mk2 , zip tied to the seat subframe - it's just out of the horizontal enough to work OK
The older I get, the better I was96 MkII in yellow & silver with bluespots, braided lines, Remus 2 into 1, Hagon rear shock & fork springs, bashplate, heated grips,Motech pannier racks, Road Attacks, Jockoiler, Baglux tank cover & bag. Gone to a far better place - hasn't it Remo?
Posted 28 May 2017 - 08:29 am
Posted 28 May 2017 - 08:58 am
just found a french installation guide.
the same guys advocate locating in front of the rear brake master cylinder
Edited by drewpy, 28 May 2017 - 12:20 pm.
Posted 28 May 2017 - 03:03 pm
That exactly where I told you mine is !
