Edited by leehenty, 06 July 2020 - 09:12 pm.
Abs Tdm
Posted 06 July 2020 - 04:10 pm
Posted 06 July 2020 - 09:20 pm
Good point Lee and worth bringing up - Vaseline on mine cos I always have some around & every time I fit new rubber
Posted 07 July 2020 - 10:51 am
Thanks Lee, I wasn't aware of that.
Posted 08 July 2020 - 05:35 pm
Posted 08 July 2020 - 06:10 pm
Posted 09 July 2020 - 09:05 pm
Rob
Posted 10 July 2020 - 07:12 am
I had the same problem on my previous 900 so after getting old one out eased the hole out a little so plenty of clearance for sensor, slipped a bit of heat shrink over the sensor slipped a very thin o ring over it along with a covering of acf50 grease and reinstalled. These sensors need checking on a regular basis to ensure no corrosion from the ally casting it is fitted to.
Posted 10 July 2020 - 10:16 am
so you reamed the hole (i'm resisting here guys) slightly bigger and took up the clearance using the heat shrink and the O ring to help keep moisture out?
Posted 10 July 2020 - 11:27 am
What type of file do you use to make a small hole bigger?
A paedofile.......
There you go Wickers I'll lower the tone for you.( I say "lower" but more of a plummet to somewhere below gutter level)
Edited by Snowbird, 10 July 2020 - 11:29 am.
Posted 10 July 2020 - 01:04 pm
Posted 10 July 2020 - 02:34 pm
You got it, tempting tho it was to lower the tone
