Bike No Starty
Posted 15 December 2010 - 12:22 pm
I went to start my bike in the cold weather and it was a arse to get started, took a while to fire up, backfiring, running on one then two pots. but once it was warm its fine.
Until yesterday, it wouldn't start, it just keeps turning and turning until flat, So i chucked the battery booster onto it, and pulled the plugs they are wet with fuel and you can smell it over the exhaust. earth the plugs to the head pot 1 ( the left hand one as you sit on the bike) sparks once when you first turn the bike over then fails to spark again, pot 2 does not spark at all. the bike turns over nice and quickly. So I am thinking the coils might be dead, I know they can be tested but you need to test them on ohms 1X scale and my multimeter is in Ohms 200, 2k, 20k, 200k, 2M, 20M, 200M So i am not sure if i can test them (yes i need to learn how to use it lol)
I have a 99 4TX model (electric fuel pump, fuel gauge)
thanks
chris
Posted 15 December 2010 - 12:39 pm
ffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffff
Hello.
When did ya last check yer leads? Sparky in the darky?
Posted 15 December 2010 - 01:26 pm
Sooooo, Now i know I have sparks, I that look nice and blue, I can smell a little fuel, it did go pop!!! and its getting air! but still no running.
I checked a taped the HT leads 2 months ago, and changed the spark-plugs at the same time.
Chris
Posted 15 December 2010 - 02:39 pm
Should start really if you have a da sparks and fuel That said, it might have flooded again.
Are you giving the fuel pump time to prime before you hit the starter ?
EDIT: I think 2K is the ohm x 1 scale on ya meter.
Edited by Studley Ramrod, 15 December 2010 - 02:40 pm.
Posted 15 December 2010 - 02:50 pm
The fuel pump is primed, and if I disconnect the fuel line it pumps it out. Going to wait until the jump-start pack is charged again, any luck that'll let all the fuel clear/plugs dry. Oddly I cant smell much if any fuel coming over the exhaust.
Posted 15 December 2010 - 03:07 pm
Last time I came across a very similar problem as yours, it wasn't good news
Moose's head gasket had blown, it was takin' about 20-30 mins of starting before it finally kicked into life.
Apologies for the scaremongerin' and I hope I'm wrong in your case, but might be worth looking into if it won't start of a booster.
Go steady with the booster as you might burn the starter motor out.
Posted 15 December 2010 - 03:37 pm
I ended up replacing mine with Silicone jobbies and all was happy.
I know the HT thing is very much a 9er issue, but might be worth a look (if you haven't already).
Posted 15 December 2010 - 06:40 pm
Hi Chris
A longer shot but...
I've a 4tx 99 build, to which I, through my own fault, introduced water into the fuel system - gives exactly the same symptoms ie sparks but no fuel/fuel smell cos the carbs wont pull a drop of water through and therefore no fuel either. The drain screws on the carbs are a blessing!!!!
Favs.
Posted 15 December 2010 - 10:25 pm
Posted 16 December 2010 - 08:32 am
I had a similar problem last weekend with the 900 - bike had not been used in about 3 weeks but was in a garage and battery connected to the Optimate. Went to start it on Saturday morning and it refused to start. I could hear the fuel pump on start up and there was fuel in the tank so could not really figure out hat was happening.
One thing came to mind from a basic mechanics course I did was the scenario of having water in the float bowls which would prevent the bike from starting. I left it and called the recovery people out in the afternoon.
The diagnosis was that the engine had flooded and in trying to start the bike a portable battery pack was drained and the recovery guy hooked the bike up to the van. After several minutes the bike fired into life but I also managed to drain the battery on the bike! Bike then stalled when I was about to take it out for a spin. Hooked back up to the Optimate it fired up the next day.
Hope this helps.
Gio
Posted 16 December 2010 - 10:45 am
Also found the 3 poll connector from the alternator has melted Now until I source a new connector I'll be on using a screw connector block? also anyone know what it needs to be rated to?
Posted 16 December 2010 - 12:58 pm
Also a little bit of rambling,
I don't have the air box on at the moment, When I try to start the bike and then stop i can see a mist coming up from the cylinders, I take it this is the Fuel air mix? I have had it back fire which meant i must of been getting spark/fuel/air even for a moment?
So If i am right by saying the mist is fuel air, then that meens i'm not getting a spark/correct spark?
I've checked the coils they are fine, only think i have taken off since it last worked is the spark plugs and put new ones in. I am getting a spark when holding the spark plug next to the block.
Is it possible that:
1) the spark it to week to ignite the fuel/air mix?
2) i'm and getting to much fuel in and its flooding the the cylinders?
also I drained the float bowls and there was a little bit of dirt in them, could that cause a problem?
Edited by Chris TDM, 16 December 2010 - 01:58 pm.
Posted 16 December 2010 - 09:49 pm
It would be strange for both coils to suddenly decide to give up.
Probably a daft question but there is poper coolant in the bike and not just water - in case the cold has cracked the head?
What voltage is the battery running with the ignition turned ON ?
Can't think of much else...APW
Posted 16 December 2010 - 10:11 pm
that the opaque coloured one that plugs into the starter relay ? i have seen them melted b4. they corrode loike the starter relay does and this leads to a heat build up when cranking over.
Posted 17 December 2010 - 12:17 pm
I think he's referring to the block connector with the three white wires, comes up from the alternator and joins up to the loom, Wicky. I tink it then reappears out the loom and connects to the reg/rec, along with a black wire and a red wire.
I wonder what could cause that to burn out ?
#16
Posted 17 December 2010 - 01:03 pm
Well I've ordered a 12mm adaptor for my compression tester, should be here Tuesday, also have a new starter relay on order
(never been changed in 35000miles) so with any luck Tuesday next week I should be a little closer to a answer.
#17
Posted 17 December 2010 - 07:38 pm
#18
Posted 17 December 2010 - 11:50 pm
Edited by Readmarx, 17 December 2010 - 11:50 pm.
#19
Posted 21 December 2010 - 08:08 pm
APW
#20
Posted 29 December 2010 - 03:27 pm
