Handling is a very subjective issue, some want it to handle like a sports bike, others want theirs to soak up the bumps and potholes. I would try dropping the yokes and see how you get on with that. Then maybe try altering the setup. Bear in mind that you'll also be altering your riding position slightly and might find you're leaning on the bars a lot more if you dropped the yokes and fitted a smaller wheel.
Wider handlebars can also help with flickability.
Yes the forks are dropped on mine by 12mm and i find this aids turn in, on a previous mk1 they were dropped 25mm but this along side a 1" longer rear shock, personally i think 25mm is too much on a standard set-up, hourses for courses i guess, the only person i'm aware of that has an 17" front is drewpy on his mk2 (same wheel) and he used an FJ i think but required shimming or some such, maybe spacer reduced or made up.
Having had a 17" on a 9r which made a good difference i'm not so sure you would benefit with one on a mk1, it already has a shorter wheelbase anyway and i find it just about perfect on B roads with an 18", not to say it could'nt be better with a 17" though ?? your only actually going to be 1/2" lower anyway so try dropping the forks 1st and see what you think..
OK, I did exactly that. What I didn't do, and now wish I had, was take a reading of a ride height.... some fixed point on the bike to the floor, I suppose. So I've dropped the forks by 20mm and very slightly rotated the handlbars backwards and obviously adjusted the mirrors and levers accordingly.
Did it make much of a difference ?
Yes, it did. the steering is definitely more...what's the word I'm looking for ?.... Fluid ! Yes, undoudbtedly more fluid, less physical effort required in bends. It IS nicer to ride.
Has it made a huge difference ? No. I won't be pursuing a 17 inch front wheel.
Am I going to leave the set-up as it is ? Sure am, I love it !
So what conclusions can I draw from this simple operation ? The centre of gravity has been lowered, which can't be bad. And the head angle has been slightly altered too, potentially giving quicker steering. A brisk run round some familiar roads seems to bear this out. All in all a good modification.
Thanks again for your advice.
Edited by curlylegend, 14 July 2018 - 03:08 pm.
