Hi, for long time I'm thinking of increasing fork travel on stock forks of 900', I know it's done successful on V-stroms.
Yamaha claims 150mm of front fork travel but this is so far from the truth, I've tried everything on bump road and ofroad and I've never have more then 100-110mm useful travel... around 15mm is taken from damper rod spring, so Yamaha sorry on front fork you can't get more then 130mm on stock setup.
On V-stroms is done by increasing fork damper rod length( some of them as far as 40mm), so increasing fork travel and ground clearance by almost 30mm.
My rear end is already higher by 20mm by adding shim under the top shock bolt(can be further increased no problem) or putting hayabusa rear shock first generation until 2006, 330mm rear shock 5mm longer then TDM and stock spring is rated same as TDMs ) with 6mm more shock stroke( should end up with 20-30mm more rear wheel travel).
My question is did anyone tried this already and can you dissemble damper rod, from pics looks like the tip is removable and can be extended or new one longer can be machined and put like sleeve. Pics are from CMSNL page and from one of CARPE members when he was modifying damper rod for emulators, ignore the extra holes .
I think extra 25mm can be added easily and that's extra 25mm of travel and around 15mm ground clearance.Or can the top of the damper rod where rebound adjuster is be dissembled and to machine longer damper tube and put it in place?
What do you think or know, and yes I ride TDM 900 light offroad too.
Edited by ratson, 08 March 2020 - 11:21 am.
