This is driving me nuts. My 9'er started and ran fine about 2/3 weeks ago. I've not been able to ride it (wrist is in plaster). Came to start it again just to keep running it until I can get out riding again and it won't start.
I've tried:
Charging the battery (twice)
Checked the plugs and there is a spark.
Fuel pump sounds like it's priming.
I took one of the hoses off under the tank, switched ignition on and got sprayed with fuel.
Checked the error codes . History shows 19, 20, 22 and 30 but each shows clear now, but only the 30 should prevent starting(?) and the bike has run since is was dumped after being nicked.
The starter turns over ok.
Clutch lever pulled in to mitigate side stand sensor issues.
Half a tank of fuel.
Tried closed throttle and opening the throttle
However, I sometimes get smell of fuel but not always (?).
I know it'll be something simple but at the moment I don't know what that something is.
