Bleeding Rear Brake. 2007 Abs
9 replies to this topic
#1 catsbum
Posted 27 July 2021 - 04:14 pm
Been hearing how hard the rear brake can be to bleed. Is there a head's up or linky anyone knows of.
Many Thanks
Cats
#2 wicklamulla
Posted 27 July 2021 - 04:44 pm
Many Thanks
Cats
oi tink there is a special tool you can buy and plug into the loom which pumps thru the fluid and aids bleeding.
#3 bondy
bondy
  • 852 posts
Posted 27 July 2021 - 05:23 pm
I don't think Randyborehole will come down from Scotland to be plugged in, to busy camper vanning I suspect. ;-)
#4 wicklamulla
Posted 27 July 2021 - 05:29 pm
:rotflmmfao:  :lol:  :good:  :badgerrock:  :clapping:
#5 Studley Ramrod
  • 19,213 posts
Posted 27 July 2021 - 08:04 pm
Some info here Martin but it's more related to changing the brake fluid on ABS models, in case you want to renew the brake fluid too.
https://translate.go...t-text=&act=url
Found the linkydink here  http://www.carpe-tdm...366&hl=bleeding
#6 PICARD
  • 1,741 posts
Posted 27 July 2021 - 09:07 pm
Yeah, I'm on this with another bike with abs. There's lots of debate as to whether special kit is needed. It's all about activating the abs pump I believe. Some say bleed conventionally, then take the bike onto grass and brake to engage abs. Depends on whether air has made it's way to the pump. A mate had to take his MV to a garage to get his rear brake working, most wouldn't touch it. Interested to see how you get on....keep us up to date and good luck.
#7 catsbum
Posted 28 July 2021 - 07:11 am
With Thanks Studders
I shall Captain. I'm not doing it for all the previous reasons, local Mechanic will be. Ordered the rear brake "hose" as I'd rather do it properly than risk another failure.
And I'm not that worried about having abs on the rear as the front end is important for me.
Hose is now on back order
Cats
#8 Catteeclan
  • 2,440 posts
Posted 28 July 2021 - 06:01 pm
Cats
Makes you wonder if they've had a few failures.
#9 leehenty
  • 5,085 posts
Posted 28 July 2021 - 08:25 pm
Find the capped connector. Short the two upper pins. It's in the abs supplement.
#10 leehenty
  • 5,085 posts
Posted 28 July 2021 - 08:31 pm
Manual for abs here.
https://www.dropbox....5_serv.pdf?dl=0
They can be a mega ballache to bleed
Edited by leehenty, 28 July 2021 - 08:32 pm.
