Posted 12 February 2016 - 08:41 pm
I'll be there, Moose will be looking on so the cake must be top quality.
The only job that can't really be done is valve shims as your engine needs to be stone cold.
Edited by leehenty, 12 February 2016 - 09:48 pm.
