Posted 06 February 2024 - 11:52 am
I recently bought another TDM900 which is all original and 10 plate registered. The colour is blue with a black frame - does anyone know what colour code this would be?
I had a look at JBX pages and it seems there was no blue colour option for 2010 so I'm guessing it's a 2009 model and the colour for 2009 is listed as Thunder Blue (DPBMX) colour type C.
I just want a touch up paint for a couple of small scratches but looking on the web I can't quite see anything that matches that text - will any of the 'Deep Purplish Blue Metallic' paints be correct?
cheers
Dan
Thats mint and only 8000 on clocks not done first shim check yet
