Tdm 900 Cylinder Head Coolant Pipe Flange Bolt Stuck
22 replies to this topic
#1 fixitsan
  • 4,671 posts
Posted 22 June 2018 - 09:45 am
A common problem, I'm going up in sizes of hex/torx/ribe to get a purchase on the allen bolt holding the top coolant pipe to the head, within the rocker coverspace
I'm trying to inspect valve clearances and change the cam chain.
If I can't free up the bolt I guess I'll have to cut the pipe, as I did for my 850, and replace the pipe itself.....but there seems to be a shortage of them on eBay (no surprise)..... does anyone have a spare or know of where I might get a reasonably priced replacement pipe in case I can't get the bolt out ?
Part number is 4NX124820000  , description is 'pipe 2'
Does anyone know if the 4tx pipe fits, it seems to be the same apart from the additional welded bracket the 900 uses to secure the pipe to a cover bolt  EG https://www.ebay.co....igAAOSw7kVbINfd
Edited by fixitsan, 22 June 2018 - 10:13 am.
#2 madmopedracer
madmopedracer
  • 473 posts
Posted 22 June 2018 - 10:10 am
are you looking for a 900 one i have one for a 850 3vd
#3 fixitsan
  • 4,671 posts
Posted 22 June 2018 - 10:14 am
It is a 900 I need...I've edited the title. Unfortunately a 3VD pipe bends in the wrong direction
#4 Studley Ramrod
  • 19,213 posts
Posted 22 June 2018 - 10:21 am
Not 100% sure, but you might manage to remove the rocker cover with the pipe still in, providing you remove the parts around it first.  Think someone on here has done it in the past.
#5 fixitsan
  • 4,671 posts
Posted 22 June 2018 - 10:27 am
There's a large bracket welded on to the pipe which would stop it from going through the orifice in the cover so I suppose I could cut that off and try. I remember it not being easy to do the same with the 850. Perhaps that was a lack of patience though :)
#6 JBX
Posted 22 June 2018 - 11:33 am
4TX pipe fits, same part (1996-2001) as the 5PS.
3VD pipe will not fit.
That pipe is imho a design flaw, not only about the well on the camshaft cover it goes in...
Should be able to remove the cover with the pipe still on, but will require a lot of cursing (and cake once it's done).
#7 fixitsan
  • 4,671 posts
Posted 22 June 2018 - 11:36 am
Thanks JB but it isn't the same due to the very large bracket welded onto it, unlike the 4tx version. Although like I say I could cut the bracket off
#8 Bjørge
  • 1,791 posts
Posted 22 June 2018 - 12:36 pm
Can't you use an extractor on the bolt, or at least drill the head off it ?
#9 dablik
  • 10,747 posts
Posted 22 June 2018 - 01:18 pm
Here Chris but a bit pricey
#10 TKH
Posted 22 June 2018 - 01:19 pm
I had to replace my pipe as it had seized in the head. £65 ........ for a bent pipe with a flange, and two pieces welded on.
Can you get a screw extractor on it?
#11 fixitsan
  • 4,671 posts
Posted 22 June 2018 - 01:31 pm
Dabs that's an oil pipe but thanks :)
#12 dablik
  • 10,747 posts
Posted 22 June 2018 - 01:36 pm
Oops soz, mind elsewhere.
#13 fixitsan
  • 4,671 posts
Posted 22 June 2018 - 03:43 pm
I could if i took the engine out i suppose but I'm trying to avoid that. Im just heading out to get a T45 3/8 socket drive, going to bash that in and try again.
#14 dablik
  • 10,747 posts
Posted 22 June 2018 - 06:26 pm
I could always send my lovely misses up to shout at it, it'll soon move :lol:
#15 fixitsan
  • 4,671 posts
Posted 22 June 2018 - 06:32 pm
Bloody hell, the very mention of it scared the bolt into submission, except it snapped off in the head !
Snapped bolt -> https://flic.kr/p/28rSgh4
Look how clean the engine is inside for 103,000 miles -> https://flic.kr/p/25FSChQ
This is the pipe, showing the additional (much heavier duty) bracket welded to the pipe  (And the reason why the cover couldn't  be slipped over it :) ) -> https://flic.kr/p/27mkkFY
I actually think (remembering from doing my 850) that with the correct sized o-ring the pipe gets clamped tightly down in the head hole and you only need the bracket to hold it in/prevent it from blowing out. I'm going to proceed with that in mind for now and when I reassemble it I'll check for leaks.
Now, I just need to find the expensive hard to find o-ring (or two !) i think the dealer will have it, I'll try Fowlers et al too
EDIT - just ordered two o-rings from Fowlers
The pipe had 2 different sized o-rings and a lot of sealant spread around....never had a coolant leak or had to top up the coolant so it must have been holding up :)
The spark plugs looked perfect , after over 5000 miles with the Samios remap, proving that it isn't over rich
Edited by fixitsan, 22 June 2018 - 07:57 pm.
#16 steve27bha
  • 783 posts
Posted 22 June 2018 - 11:16 pm
Chris,
I reported on fettling my coolant pipe during a valve check here. There's pix and details of O rings, of which I have more if you want/need.
Here's a pic of my pipe before removal - strangely no side bracket arm!
Attached File  3 Mucky cover.JPG   158.16KB   2 downloads
#17 fixitsan
  • 4,671 posts
Posted 23 June 2018 - 07:39 am
I remember that post Steve, and I have a selection of o-rings, When I did the 850 I used 2 Stacked but they weren't the exact size proper good ones, but close enough.
I'll start with the correct ones first and go from there.
Very interested to see you had no bracket, and yours is such low mileage that it is unlikely to have been swapped for an 850 one..... It must either be a factory mod or someone's bright idea. it's very robust so fingers crossed !
#18 wicklamulla
Posted 30 August 2018 - 10:23 pm
Chris with that additional bit on your coolant poipe,   did a cam cover allen bolt pass thru it thus securing it in 2 separate locations ?
#19 fixitsan
  • 4,671 posts
Posted 31 August 2018 - 06:57 am
Indeed it did, And is now the only bolt holding it. I've ridden over 1000 miles like this and no coolant loss
#20 wicklamulla
Posted 31 August 2018 - 07:33 am
ya reckon it was a home brewed modification?
