Is me chain fooked?
28 replies to this topic
#1 Edman
Edman
  • 157 posts
Posted 27 November 2006 - 03:09 pm
Well, is it fooked? Is this the daylight you all refer to?
#2 duibhce Kaelann
duibhce Kaelann
  • 1,147 posts
Posted 27 November 2006 - 03:14 pm
not necessarily f$cked, but does need immediate tensioning.
If you adjust the tension now and in 2 or 3000 km you can see daylight again, then it definitely needs replacing.
A bit hard to tell from the pic but the sprocket still seems quite alright.
Yamaha XJ600S Diversion '94
Yamaha XJ900S Diversion '97
Suzuki SV650S '01
Yamaha TDM900 '04
#3 cyco900
cyco900
  • 269 posts
Posted 27 November 2006 - 03:48 pm
has it got any side play in the middle of the chain run? ie. will it move toward the wheel and away from it by more than say 1/2''.
are the sprocket teeth sharp points or worse hooked?
if either its shagged......sorry
Boring Old Fartz mcc / Diflas Hen Rhech - the PARTY club
[b]Now 03 TDM900 and Honda 450 Cafe Racer - previous bikes:- 97 virago535 -Triumph Trophy900- TDM850Mk1- Honda VF750F- Honda CB350K4- Honda CB650F chop- Suzuki 100- Honda CB900F x2 -Honda CB250 Dream -Kawasaki K400 -Honda CB650F Chop- Honda CB750K2- Kawasaki Z1000- HD Sportster1000- Triumph 500t- Honda 400/4- TriBsa 650- BSA C15- Triumph Speedtwin combo -BSA B33 chop- BSA A65 -BSA A10 chop- Ariel Golden Arrow- BSA Bantam- Francis Barnet- NSU Quickly. think thats the lot?
(\__/)
(")_(")
bunny hoppin
Sign by Dealighted - Coupons & Discount Shopping
#4 andyj
andyj
  • 611 posts
Posted 27 November 2006 - 03:59 pm
Looks as knackered as the one on my winter hack. Luckily I've the replacement chain & sprockets sat in my garage waiting for the Christmas break to fit. Thank heavens for eBay. Good deals do come up occasionally. I think I paid £15 plus £9 p&p for a DID chain & JT sprockets!
Another boring night & I'm feeling pissed....
#5 Dave284
Dave284
  • 28 posts
Posted 27 November 2006 - 04:12 pm
Its knackered, get the chain and both sprockets changed.
Is the beast the bike, the car, or half a dog?
2005 TDM900 silver. Learning from the David Coulthard book of racing excuses.
#6 Edman
Edman
  • 157 posts
Posted 27 November 2006 - 05:30 pm
QUOTE(cyco900 @ Mon 27th Nov 2006, 04:33 PM) <{POST_SNAPBACK}>
Teeth are not pointed, and it has got a bit of side play, but wouldn't have thought it moved 1/2", maybe 5 mm odd
QUOTE(Dave284 @ Mon 27th Nov 2006, 04:57 PM) <{POST_SNAPBACK}>
'Is the beast the bike, the car, or half a dog?
The car is certainly no beast, plus I reversed into a lampost recently ranting.gif , so if anything it's a beast with a limp blink.gif
The dog is no beast either, most people think he's a bitch - very gentle he is! giveusahug.gif
As for the bike, I called it a beast - won't be able to do that once I got me 900
#7 Guest_GuyGraham_*
Guest_GuyGraham_*
Posted 27 November 2006 - 07:31 pm
Looks fine to me mate.
When you can pull it clear of the teeth, then its had it.
QUOTE(duibhce Kaelann @ Mon 27th Nov 2006, 02:59 PM) <{POST_SNAPBACK}>
This has nothing to do with the chain adjustment - this is checked by the amount of slack in the middle of the chain, between the Fr & R sprockets. You want about 40mm on a Mk11
To be honest, O/X-ring chains don't get to that state. without needing to be adjusted after every ride (no grease left insid ethe chian - hence frequent adjustment). When it needs adjusting after every ride, then its had it.
Edited by GuyGraham, 27 November 2006 - 07:33 pm.
#8 bondy
bondy
  • 769 posts
Posted 27 November 2006 - 07:35 pm
QUOTE(Edman @ Mon 27th Nov 2006, 02:54 PM) <{POST_SNAPBACK}>
Ed, you really should clean that bike mate.
#9 cupasoop
cupasoop
  • 367 posts
Posted 27 November 2006 - 07:39 pm
#10 dandywarhol
  • 5,030 posts
Posted 27 November 2006 - 08:50 pm
Thats a generator for his pacemaker fitted to the front wheel rotflmmfao.gif
1967 Yamaha TD1C 250, 2016 KTM Duke 690
#11 Guest_Emmett_*
Guest_Emmett_*
Posted 27 November 2006 - 10:05 pm
QUOTE(bondy @ Mon 27th Nov 2006, 07:20 PM) <{POST_SNAPBACK}>
#12 Edman
Edman
  • 157 posts
Posted 28 November 2006 - 08:03 am
If I took photos of the bike, its cos I just cleaned it, having forgotten what it looked like without all the crud. Plus the local supermarket own branded furniture polish (bit like Pledge) gave some rather good looking results smile.gif - though in 2 days the effect has gone dull
Extra wire is not for me pacemaker (cheers Dandy and fook off laugh.gif ), but for the bike counter (top right of clocks) cos in France need to see kmh speed and dial is not accurate enought
Which throws up a quick question - if I do 100 kmh on the TDM dial, the bike counter shows a real speed of 98 kmh, while the TomTom Shitenav shows 103 kmh?? (used the recommended wheel size as calculated by Dandy in previous forum)
So question is - do Satnavs add an element of over displaying speed similar to car speedos, or is that pretty damn accurate, in which case Dandy you need a good punishment.gif
#13 Jez
Jez
  • 722 posts
Posted 28 November 2006 - 09:00 am
I think the chain is on it's way out but I have known worse. When you find yourself having to adjust it more and more often then you will need a new'un pretty quick.
Even if the sprockets look ok I recommend replacing them both at the same time 'cos if they are only slightly worn they will feck the chain quick. Especially relevent if you will be splashing out on a good chain - skrimping on sprockets is false economy imho. I have some expensive DID Xring and have not adjusted it yet after 2000 miles from new.
If you only have 5mm of sideways play then this confirms my theory that there is stil some use in left it. When it goes really bad the whole chain feels rattly and loose in your hand 'cos all the grease holding capacity has gone out of it, like GuyGraham said in here.
As for lifting it off the sprockets then yes what you have shown is the daylight we talk of and some say that if there is enuff daylight to fit a pencil through then it has had it, I wouldn't wait that long though.
Great looking bike btw. Don't see many that colour down this neck of the woods.
#14 dandywarhol
  • 5,030 posts
Posted 28 November 2006 - 02:56 pm
I'd say the chain has seen better days and run it much longer and you'll hook the sprox.
GPS seems to be as accurate as it gets I.M.H.O.
#15 TonyDevil
  • 9,319 posts
Posted 28 November 2006 - 03:41 pm
QUOTE(dandywarhol @ Tue 28th Nov 2006, 02:41 PM) <{POST_SNAPBACK}>
cruising at a constant speed the GPS will be VERY accurate. something silly like +/-0.01mph variance.
current rides : TDM850 3vd/mk1=tourer&scratcher, TRX850=weekend twisty toy, TDM900=commuter, Z750 hardtail=project
gone but not forgotton : XTZ750=overland touring toy, GS500e, GS125
If you don't like my answers you should cease asking stupid questions!
#16 Landy
Landy
  • 1,387 posts
Posted 28 November 2006 - 03:56 pm
QUOTE(Toneski @ Tue 28th Nov 2006, 03:26 PM) <{POST_SNAPBACK}>
I agree if your speed is changing it sometimes takes the GPS a little time to catch up but when your speed is stable the GPS is about the most accurate you can be. Any lag will be more apparent if only a couple of satellites are locked on.
#17 dandywarhol
  • 5,030 posts
Posted 28 November 2006 - 06:38 pm
QUOTE(Edman @ Tue 28th Nov 2006, 08:48 AM) <{POST_SNAPBACK}>
#18 PICARD
  • 1,082 posts
Posted 28 November 2006 - 07:17 pm
QUOTE(dandywarhol @ Tue 28th Nov 2006, 08:23 PM) <{POST_SNAPBACK}>
whats that lookin out from the back of the garage?? if thats it's head it must be huuuuuuuge!! shocked.gif notfunny.gif
#19 Doc
Doc
  • 231 posts
Posted 28 November 2006 - 09:10 pm
Shouldn't a worn tyre increase the apparent speed on the TDM dial and Bike counter? But I agree - the tyre size will affect the TDM dial and Bike clock, by ~2% per 5mm difference. The figures all seem pretty close to me.
I think my TDM may be over estimating, at least based on milage. I went to see my mum last Thursday - 208mlie round trip on the TDM. My wife went to see her mum on Friday - 198 mile round trip in the car. And HER mum lives a mile further past my mum! blink.gif Perhaps I'll follow Edman's example and fit a few more speedo's.
#20 bondy
bondy
  • 769 posts
Posted 28 November 2006 - 10:04 pm
Edman
Edited by bondy, 28 November 2006 - 10:04 pm.
