I saw this on another forum. I've never seen it before, so thought I'd share. Ali
Posted 29 December 2021 - 05:14 pm
Posted 01 January 2022 - 10:50 pm
Yes, this does work. I just haven't figured the Physics ? Maybe someone here could explain ?
Posted 02 January 2022 - 11:27 am
I am no physicist but I can imagine that if the wheel was able to turn to right angles to the bike then it would be really easy to pick up, or even hard to keep upright.... (?)
Posted 03 January 2022 - 04:31 pm
as the forks are at an angle and forward of the head stock, the bike must want to tip to where the front wheel is pointing, if you point it the opposite side then it wants to tip that way.
