It's Alive!
8 replies to this topic
#1 drewpy
  • 1,758 posts
Posted 01 July 2020 - 06:39 pm
Got the engine going and no real nasties
I checked the carbs today with a break in the weather and they were not seated properly and that's why it wouldn't run.
https://youtu.be/trzUJ7E_hK0
just a few things;
fuel leaking from fuel tank tap
carbs need balancing
connect the fan
a lot of this would be from sitting in the shed and the rubber drying out as I had a fuel pipe let go too.
probably renew them all agin as a couple years old now
Edited by drewpy, 01 July 2020 - 06:43 pm.
#2 leehenty
  • 5,091 posts
Posted 01 July 2020 - 07:55 pm
Whoop whoop
#3 Studley Ramrod
  • 19,217 posts
Posted 01 July 2020 - 08:39 pm
:banana: :yahoo: Well done Drewps.
#4 Snowbird
  • 1,359 posts
Posted 02 July 2020 - 06:15 am
Nice one Drewpy.
#5 madmopedracer
madmopedracer
  • 473 posts
Posted 02 July 2020 - 08:36 am
after a layup my fuel tap leaked when moving it but with it in the off position the mist of a leak stopped after a day and is fine now
#6 drewpy
  • 1,758 posts
Posted 02 July 2020 - 09:35 am
mine was a bit more than mist.
ordered o rings as probably original anyway
#7 Pedro
Pedro
  • 266 posts
Posted 02 July 2020 - 08:08 pm
Sounds nice with those pipes. I wonder if I can convert a 3vd engine into a 4tx?
Edited by Pedro, 02 July 2020 - 08:09 pm.
#8 Snowbird
  • 1,359 posts
Posted 02 July 2020 - 08:19 pm
Probably worth looking around for a second hand 4tx engine going by your crank issues, were the mk2a's as bad for oil burning or was it just the early ones?
#9 Studley Ramrod
  • 19,217 posts
Posted 03 July 2020 - 07:35 am
Mk2a's do use oil.  Seems that some are worse than others, just like the mk1 really.
