900 Oil Tank
8 replies to this topic
#1 jasw
jasw
  • 2 posts
Posted 06 August 2022 - 04:34 pm
How do you remove the oil tank on the 900,
#2 dapleb
  • 18,120 posts
Posted 06 August 2022 - 04:52 pm
Hello dare and welcome
#3 catsbum
Posted 07 August 2022 - 02:39 pm
Welcome
Why?
#4 jasw
jasw
  • 2 posts
Posted 07 August 2022 - 06:53 pm
Stupid mistake, after oil + filter change last week realised oil level to high. Used a large syringe and some tubing to remove some oil first couple was ok third time tubing fell in to the tank :rant: . Was concerned incase it could possibly restrict oil flow or break up over time so thought it best to remove asap.
Anyhow maybe I'm stupid (probably) but could not get the tank out. Ended up having to pivot motor forward on bottom eng mount to get enough clearance, removed sensor on bottom of tank and managed to get the tubing out. Pig of job though :( , luckily I'm retired with nothing better to do  :D.
Cheers Jimmy.
#5 Snowbird
  • 1,359 posts
Posted 07 August 2022 - 07:37 pm
If it's any consolation I have a jerry can that rattles like hell due to the tip of a pouring spout that's been in there a couple of years, not nearly as critical but it happens to us all usually through badly thought out shortcuts, often planned in the pub...
#6 catsbum
Posted 08 August 2022 - 05:53 pm
Cheers Jimmy.
Poor you Jimmy!
If it helps I've done worse.... :punishment:
#7 Pedro
Pedro
  • 266 posts
Posted 08 August 2022 - 08:26 pm
Would one of those flexy grabbers do? They've got me out of a few stupid mistakes in the past.
Speaking about lost items in fuel tanks, a few years ago I used to demolish pine trees for firebreaks on a Cat D7. We had to remove the tank to do some repair and when we drained it, found someone's wallet with money and ID. Never found out how it got there. Couldn't read the ID.
Edited by Pedro, 08 August 2022 - 08:27 pm.
#8 leehenty
  • 5,091 posts
Posted 09 August 2022 - 04:03 pm
I would have loosened the M10 drain screw on bottom of engine to drain a bit out
#9 Studley Ramrod
  • 19,217 posts
Posted 09 August 2022 - 06:16 pm
Cheers Jimmy.
Blimey !  Good to hear you sorted it :good:  and jealous to hear that you're retired :lol:
