Chain Care
Dreadful things
30 replies to this topic
#21 fixitsan
  • 4,676 posts
Posted 14 March 2017 - 09:13 am
Nowt wrong with a bot o rust !
My daughter's boyfriend has been running his new YBR125 through winter and when we were at the Scottish bike show this weekend he complained that the chain was rusting on the side plates. I explained that the critical component is the o-ring area, and as long as that is lubed and not rusty the outer sideplate rust isn't really a sign of a knackered chain (although it is contagious once it sets in)
I spin the back wheel while holding a brass wire brush to the outer side (if the chain is really bad), and then chainwax or grease on the outside keeps the plates free from corrosion for a long time and I use any oil, thicker the better, for the o-rings.
I used to always run a bike daily through winter on very salty Scottish roads, and if the chain ever developed a tight spot a soak in white spirit (brush cleaner) for a few hours, then hung up to dry for a few hours, then an overnight bath in the old engine oil tray worked wonders.
If a chain tightens during winter I keep it going till spring arrives and the salt has gone, then change the C&S...cannot see the point in murdering a new C&S mid winter
#22 Gauntlett
Gauntlett
  • 77 posts
Posted 14 March 2017 - 11:14 am
I have a lubman oiler fitted, you control frequency and amount, use engine oil. Been on three years now only adjusted chain once about 4k miles per year. oh and cheap to.
#23 TinTin
TinTin
  • 1,296 posts
Posted 17 March 2017 - 08:32 am
Now I really like that. I have found that with me (& Charlie Brown) things that are supposed to "automatically" happen don't.
So I'm going to give one of these a go for the ER6. At that price it wont break the bank if I don't get on with it.
#24 TDM4ever
TDM4ever
  • 302 posts
Posted 14 April 2017 - 11:58 am
I have always used 90W chainsaw oil. Very sticky and cheap.
My chains have never rusted, lasts forever and stays clean.
#25 stevierst
stevierst
  • 51 posts
Posted 14 April 2017 - 01:28 pm
I used the lubeman oiler when they first came out about 15 or so years ago, and found it to be pretty good. But being a proper tight arse I've made one or two for my later bikes out of an old hand soap bottle and plastic tubing, worked as good if not better than the original squeeze bottle the lubeman.
Filled with engine oil makes a better winter oiler than the scottoiler system, as these tend not to let the oil flow in cold weather, and scottoil washes off at the first sign of rain!
Stop polishing it and ride the bloody thing!
The current stable
04 TDM900. My work/winter/touring donkey.
The Work Of Idle HandsVI :- 2016 Yamaha XSR900 with a few tweeks:badgerrock:
#26 trevini
trevini
  • 1,777 posts
Posted 14 April 2017 - 02:17 pm
Scottoiler here. I've been using engine oil/gear oil in it for years as I'm too tight to buy proper Scottoil (although I do have some at the moment as it was donated to me). Generally, I get about 28-30k miles from a chain and sprocket set, with the front sprocket wearing first.
2004 Galaxy Blue. Owned since 486 miles.Renthal 755 bars, Bagster tank cover, Oxford heated grips, DL650 hand guards, Double Bubble screen, Scorpion Rad guard, Gel pad insert, HLD undertray, Angry Badger tailtidy,  Michelin Road 5s, Givi E21s, E46 topbox, Ohlins shock and YSS cartridge emulators   Currently not fitted - PC3, Remus Revolutions.
#27 TinTin
TinTin
  • 1,296 posts
Posted 15 April 2017 - 12:21 pm
I have some 100W chain saw oil. How do you apply yours
#28 Catteeclan
  • 2,440 posts
Posted 18 April 2017 - 09:02 pm
#29 Studley Ramrod
  • 19,214 posts
Posted 19 April 2017 - 10:06 am
:lol:
Think I might try the engine oil in my scottoiler loike wot Trev does. :)
I'd prolly brush it on Sam.
#30 chrisbee
chrisbee
  • 392 posts
Posted 19 April 2017 - 06:42 pm
I saw this stuff in a shop the other day...
is it ok for a bike chain??
#31 wicklamulla
Posted 20 April 2017 - 05:12 pm
  dunno but i usually have a 25lt drum of chain i'll beyont in me garage so i shud try it in me Scotoiler.
