Small Coolant Leak
Posted 24 July 2014 - 02:56 am
Posted 24 July 2014 - 06:04 am
Think that's a relief hole for fluid to escape the water tube area that fits in the top of the head. Could be the O ring on said tube or most likely the thermostat housing.
Posted 24 July 2014 - 07:27 am
I have a small hole on my 3vd which weeps a little oily substance from time to time. Been told it's normal! Not sure about coolant though??
Posted 24 July 2014 - 08:17 am
It also allows water to flow away from the recessed spark plugs. I agrozzle, could be a leaking thermo housing. The leak only started happening on my mk1 when the engine was up to temp, it then leaked from the housing onto the rocker cover and down the plug hole. The thermo housing plastic cover has a tendency to warp, silicone sealant usually cures the problem.
Posted 24 July 2014 - 01:53 pm
I've had a similar amount of coolant mysteriously appear on the garage floor with my Mk2 that had been stood for 6 weeks. It had been well behaved otherwise.
Found a little more in the belly pan too.
Took it out for a ride in defiance. NO ISSUES, thousands of miles later.
It may be that a leak is possible if the motor is left standing
My advice; is go for a couple of ickle rides first, look for summat obvious before any dismantling. Park it in a place where you'll see any more pooling.
Have a good sniff.
You might just fix this by taking it for a ride.
Posted 24 July 2014 - 02:02 pm
Posted 25 July 2014 - 06:47 am
