Hi All
I am back in the club as of tommorow.
I have gone to the dark side and pick up a 2003 900 tommorow.
You can all look forward to many searching questions on the best way to improve it over the coming months.
Doggy
Posted 27 August 2021 - 05:10 pm
Hi All
Doggy
Posted 27 August 2021 - 05:50 pm
Posted 27 August 2021 - 07:38 pm
Posted 27 August 2021 - 08:15 pm
We’ll have to have a local meet up at some point. Maybe a run down to Route 11 for a cuppa?
2004 Galaxy Blue. Owned since 486 miles.Renthal 755 bars, Bagster tank cover, Oxford heated grips, DL650 hand guards, Double Bubble screen, Scorpion Rad guard, Gel pad insert, HLD undertray, Angry Badger tailtidy, Michelin Road 5s, Givi E21s, E46 topbox, Ohlins shock and YSS cartridge emulators Currently not fitted - PC3, Remus Revolutions.
Posted 28 August 2021 - 09:21 am
Posted 28 August 2021 - 09:22 am
Posted 28 August 2021 - 09:28 am
Next time I'm back home in the flat lands, I'll try bump into you all for a brew.
shout when you’re heading over, I’ll put the kettle on.
Posted 28 August 2021 - 05:02 pm
Posted 28 August 2021 - 06:50 pm
Posted 28 August 2021 - 07:57 pm
Posted 29 August 2021 - 07:05 am
Posted 29 August 2021 - 07:59 am
Posted 29 August 2021 - 10:03 am
Posted 29 August 2021 - 10:18 am
I had them already!
Posted 03 September 2021 - 12:13 pm
Picked it up, great ride back even though it was raining. Love the way it punches out of corners. Let the tidying up begin!
Mod #1 - 16 tooth front sprocket, if you like punching out of corners you will like it even more afterwards
Posted 04 September 2021 - 12:33 am
Posted 05 September 2021 - 04:37 am
Edited by Gdogg, 05 September 2021 - 04:37 am.
Posted 05 September 2021 - 09:44 am
On the TDM I use a relay for peace of mind which needs a bit of wiring and finding the right cables, etc. If you are OK with that all is well. But for the not so accomplished there are easier, if pricier options. Just to make it neat and simple I installed an unfortunately named Healtech 'Thunderbox' on one of my other bikes. All that needs doing is connecting to the battery. Any device connects to some clip connectors on the box. It will then power, fuse and switch off your device for you. Works a treat. There are others like it out there. And its not bigger than a relay.
Rob
"Healtech 'Thunderbox'"
Nice simple solution for everyone ! More expensive than using discrete components but saves a lot of messing around
Posted 06 September 2021 - 03:48 pm
Healtech 'Thunderbox' sounds like the way to go, i am a complete no hoper with elictrical stuff.
Thanks for the advce guys.
Doggy
Posted 06 September 2021 - 07:11 pm
Any piccies of the bike ??
