Whats This For?
15 replies to this topic
#1 Doggy
Doggy
  • 379 posts
Posted 29 August 2021 - 10:15 am
Hi All
On taking the seat off, i found this connector sitting alone and unloved.
What is it for and do i need to connect it to something?
#2 thong
thong
  • 50 posts
Posted 29 August 2021 - 11:49 am
maybe to connect to a battery charger ?
#3 catsbum
Posted 29 August 2021 - 12:43 pm
I agree with Thong. Follow the cable and see where is goes.
#4 Doggy
Doggy
  • 379 posts
Posted 29 August 2021 - 02:01 pm
Thanks guys
#5 dablik
  • 10,757 posts
Posted 30 August 2021 - 10:54 am
If memory serves that looks like the sidestand switch connector ?? has it been disabled ! mind it's a bit long though..
#6 fixitsan
  • 4,676 posts
Posted 30 August 2021 - 01:19 pm
Heated grips fitted ?
#7 Doggy
Doggy
  • 379 posts
Posted 30 August 2021 - 07:05 pm
Yes heated grips fitted, not tried them yet though.
#8 steve27bha
  • 784 posts
Posted 30 August 2021 - 09:06 pm
I suggest you stick meter probes inside and see what power you get if any and if it is switched with the ignition. That end looks like it goes inside summat so more likely to be attached to an item that uses the power than a supply..
What colours are the wires? I see grey and grey/black, but they are grubby too. A run thru' the wiring diagram I have for the 900 finds only two wires with any grey and neither paired with a second grey, so I suggest you have an aftermarket item, and need to trace its run.
Given it's loose I suggest a battery charger pigtail, but it is not of the types I've seen on an Optimate; or hotgrips.
Oh, and you could update your avatar model info. to show you now have a 900.
#9 Doggy
Doggy
  • 379 posts
Posted 31 August 2021 - 04:26 pm
Thanks for the info, off to the garage as now finished work. I have indeed updated my picture. Cheers Doggy
#10 TDM4ever
TDM4ever
  • 302 posts
Posted 02 September 2021 - 01:37 pm
It's for the Flux Capacitor. Be careful if you connect it, you never know where you end up...  ;)
#11 Doggy
Doggy
  • 379 posts
Posted 02 September 2021 - 06:17 pm
Too late, writing to you from 2045. All bikes are electric!
#12 Snowbird
  • 1,359 posts
Posted 02 September 2021 - 06:42 pm
Being in norfolk you are more likely to find yourself back in 1973, just by walking out the door..... :hide:
#13 PICARD
  • 1,744 posts
Posted 02 September 2021 - 07:21 pm
Ah Norfolk 1973...happy days!
BSA bantam, bike test in a hour,peas and tripe on Yarmouth market....brings a tear to my eye!!
#14 Doggy
Doggy
  • 379 posts
Posted 06 September 2021 - 04:13 pm
It was connected directly to the battery, but isnt anymore!
Still dont know what it was for, but hey it aint there anymore.
Doggy
Cheeky!
#15 PICARD
  • 1,744 posts
Posted 06 September 2021 - 06:16 pm
That was defo flying lead for battery charging. There was one the same as that on my optimate before I butchered / modified it.
Edited by PICARD, 06 September 2021 - 06:16 pm.
#16 Doggy
Doggy
  • 379 posts
Posted 08 September 2021 - 05:21 pm
Oh, all the chargers Ive had have had the female plug from the battery with a rubber cover. How odd.
