Hi All
Where is the best place to get a switched live to power my sat nav?
How would it be done? (Elictrical Idiot here)
Cheers Guys and Gals
Posted 03 September 2021 - 02:25 pm
Hi All
Posted 03 September 2021 - 03:05 pm
Hi All
Handlebar brake switch on the front brake lever. But only if the Satnav uses under 1Amp of current (check on the label).
The pilot lamp in the front fairing is switched too.
If the satnav is going to take more than 1Amp then you might be better off running a proper switched live from the battery
Otherwise run a new switched feed from the battery, via a relay operated by an existing switched live, such as for the rear lights or rear brake switch
Posted 03 September 2021 - 04:38 pm
i made a relay switched 4 way fuse bus. then i could add or take off stuff with ease.
have satnav, heated grips, dash cam and something else i can't remember
4tx850
Posted 03 September 2021 - 05:37 pm
I got this from the RE Himalayan forum and installed one on my niner. I am not great electrically, but it was fairly straightforward. I intend adding DRLs and heated grips, so can add them easily.
Posted 03 September 2021 - 05:48 pm
I just added a relay from a switched feed on mine, which now powers up heated grips, Stebel Magnum horns, sat nav, twin power sockets for phone charging/air compressor (when needed for tyre inflation if touring) and camera power when used.Each extra circuit separately fused.
2004 Galaxy Blue. Owned since 486 miles.Renthal 755 bars, Bagster tank cover, Oxford heated grips, DL650 hand guards, Double Bubble screen, Scorpion Rad guard, Gel pad insert, HLD undertray, Angry Badger tailtidy, Michelin Road 5s, Givi E21s, E46 topbox, Ohlins shock and YSS cartridge emulators Currently not fitted - PC3, Remus Revolutions.
Posted 03 September 2021 - 10:27 pm
I think these are useful, relay and fuse all in one
https://www.ebay.co....8sAAOSwPyBZrS-X
Or if you're throwing all your cards in, go for the multi fuse version !
https://www.ebay.co....PkAAMXQLbVRbWH0
