Now then, finally started working on replacing that cam-chain.
I got Haynes next to me while doing all this. After some initial stages in the demolition process I am about to take off the camchain sprockets.
According to Haynes, one should turn cylinder 1 into TDC (cam-lobes facing away).
After doing this, you should get a situation where the "I" mark on the inlet side should align the "E" mark on the exhaust side.
Well, this is what I am looking at:
It's no less than 2 teeth out of line
Does this mean I have been riding around with the wrong timing (is that possible without things blowing up?), or does Haynes description apply to the older TDM/XTZ engines and not the 270 degrees engine and this is correct on mine (2001 model TDM)? I am possibly talking bollocks here but rather that than bollocksing the engine by changing it.
Thanks for suggestions, I am a bit at a loss at the moment
Edited by robelst, 13 January 2007 - 02:24 pm.
