Posted 11 July 2014 - 11:10 pm
Trumpet means British Triumph of the 1950's. it's much easier to work on than modern machines, very satisfying, things were much simpler back then.
Distributor body is made of cast iron and the rotor shaft was rusty and quite pitted. I turned off the pits in the lathe by 0.15mm, then made undersized bushes pressed in to fit the slightly over size 0.20mm cleaned up bore in the body.
Good as new, should last for many years now. The bike has just over 3000 miles on the original clock.
It's the standing that did the damage, not miles.
I'll need to give it a short test run of er 200 miles ? ..... I may be some time
Edited by leehenty, 12 July 2014 - 09:22 am.
