does anybody know what the correct helicoil kit is for the sump drain bolt ? was doing oil change etc and the thread has had it so gotta repair the thread , i know its a 14mm thread but there are a couple of helicoil kits with different thread pitch etc so dont want to buy wrong one . if it makes any difference the sump bolt is one of the magnetic ones not the original and its an 02 900 . cheers guys
1 reply to this topic
Posted 14 February 2024 - 02:08 pm
Posted 14 February 2024 - 02:43 pm
M14x1.5 I just pitched a spare plug
Edited by leehenty, 14 February 2024 - 02:46 pm.
