Posted 17 April 2014 - 10:47 am
I have considered one, but there are a few caveats. The floor needs to be smooth and level, there is only one locking pin point at full extension. I wouldn't be happy holding a a bike on the hydraulic jack only at some intermediate point, it would be more useful for have multiple locking points on the way up.
They also don't show if it is collapsible as when not in use you have to store it somewhere.
Lastly cost, by the time you have all the bits and delivery it's north of £450.
Swmbo has vetoed this proposed 'investment'
